Results 1 to 25 of 27
Thread: Car running hot
    DX User my89LXihatch's Avatar
    Jan 2007
    1989 Honda Accord LXi Hatchback,2005 ford f-150, 1996 mitshbshi eclipse gs,2004 Honda Accord EX-L sedan
    Savannah Georgia
    Car running hot
    My 89 LXi Hatch over heated and blow a huge plug out the top of my radiatior. It was July 4th my daughter was in very heavy traffic bearly moving. I have since replaced the radiator and the hoses. When driving everythings good.It even runs cooler than before.Problem is it can get pretty hot, close to the danger zone.My question is this. The fan will come on when the car is off, but it dose run when the car is running. Should it run when the the engine is running to cool it down. By the way it also has A/C problems.
    Re: Car running hot
    did you bleed the system after you installed everything?
    You may have air still trapped in there
    Millington, TN
    Re: Car running hot
    Did you replace the thermostat?
    Phil
    Re: Car running hot
    Quote Originally Posted by nswst8
    and remember to replace it with a OEM honda one. it fixed my overheating problem.
    Jan 2007
    Savannah Georgia
    Re: Car running hot
    Yes we did replace the thermostat and we flushed the system. Even added a pressure release cap.
    Re: Car running hot
    is the water pump fine? when was the last time you changed it?
    Jan 2007
    Savannah Georgia
    Re: Car running hot
    I have never replaced the water pump. Water is flowing though the system though.
    Millington, TN
    Re: Car running hot
    Quote Originally Posted by my89LXihatch
    Are you talking about a lever preasure release cap?
    Make sure that you have the correct PSI rated radiator cap.
    Phil
    Banned ahmad89's Avatar
    Dec 2006
    Re: Car running hot
    so your fans dont turn on when the car is running? i wired my fans to a switch and ever since i did that my car hasnt over heated at all, maybe your thermo sensor is going out.
    Re: Car running hot
    So let me get this straight, you did not bleed the system?
    Jan 2007
    Savannah Georgia
    Re: Car running hot
    Bleed the coolant system? I flushed after the new parts were put on. But is the fan supposed to kick on while the car is going, and the temp rises, or do you use the A/C and that fan running is suffent for cooling the engine. A/c is not working right now. So could that be a problem.
    Re: Car running hot
    there is a bleeder valve on the thermostat housing to released the trapped air in the system, check that first to see if that solves the overheating problem
    Sep 2003
    '89 LX
    Virginia
    Re: Car running hot
    The fan should turn on when the car is running and at the normal operating temp (the temp needle should be slightly below the middle mark on the guage), regardless of whether your A/C is on or not.
    03/01/08- 129,000 miles
    10/19/08- 136,000 miles
    Blue 3geez
    10.8.06 Photoshoot
    1.7.07 Photoshoot
    Dec 2006
    Re: Car running hot
    bleeding the system really helps just keep loosening the bolt wait a sec then close it then repeat a few times and top off but be careful that bolt likes to break off so dont tighten it too tight just tight enough so no more fluid comes out.
    Jan 2007
    Savannah Georgia
    Re: Car running hot
    Thanks. I didn't know about the bleeding. Learn something new all the time. I will try that. Thanks.
    Re: Car running hot
    Quote Originally Posted by ahmad89
    It not only helps it is necessary.
    Dec 2006
    Re: Car running hot
    didnt say it was but thats most likely the issue, dam russians
    Re: Car running hot
    After you bleed the system drive around and and make sure it doesn't over heat. Then feel the bottom radiator hose, it should be hot. If it isn't hot, then you have a problem with your radiator being clogged, which it shouldn't be as you said you replaced it. Thermostat which you also replaced, and then the water pump which you didn't replace. Just try bleeding it and see what happens. Just do not over heat it or you will warp the head or blow the head gasket, both of which are not fun.
    SE-i Sedan 5 spd
    Re: Car running hot
    Here's what you do:
    Fill the overflow bottle to somewhere above the minimum mark.
    Open the radiator cap
    Slide the heater control to Hot
    Open the bleeder valve on the top of the thermostat housing
    Start the car and let it come up to temperature
    Add water to the radiator as needed
    When the water stops spitting out of the bleeder valve (e.g. comes out in a steady stream), close it and tighten....not too hard.
    Replace radiator cap
    Nov 2006
    Re: Car running hot
    Lots of good advice here but I will repeat what Toneloc5145 said ...to make sure the radiator fan turns on when the temp is up to (or slightly above) normal. When driving at 30 mph or above there is enough air moving through the radiator that the fan will not usually come on. But stuck in traffic, with no air movement, if the fan does not cycle, it WILL OVERHEAT. So after all is checked out, the car is up to temp. park & idle it. Verify that the fan will cycle on when the temp gauge starts to rise.
    SE-i Sedan 5 spd
    Re: Car running hot
    BTW, an early warning of a low coolant level is the idle beginning to fluctuate and the temp gauge moving around. What has happened is the level in the coolant bottle has (finally) dropped too low, and air has gotten introduced into the system. If you're losing your idle speed, look at the coolant level pronto. And after adding coolant, do another bleed.
    One of the more aggravating features of our cars is that the coolant bottle is way down there where it's hard to see. And, the inside of the bottle is usually stained from mineral deposits. Consequently, you tend to put off checking the level....until it's too late. The fix is to remove the battery, take out the battery tray (not a big deal), and remove the bottle. Clean it with something like "The Must For Rust" (get it at KMart etc), or Milk Stone Remover, anything with phosphoric acid in it. It will get rid of the rust stains.
    Another approach is to take off the cap of the bottle, and use a dipstick to check the water level. Or, you can just fill the bottle up. It will be kind of messy the first time you drive the car, as it regurgitates the excess coolant onto the road. That's bad manners, plus antifreeze is poisonous and sweet, and just a little bit is a deadly combo for dogs.
    Re: Car running hot
    hope the blead valve helps
    Jan 2007
    Savannah Georgia
    Re: Car running hot
    Thanks for all of the advice. I do know from checking, that when the car heats up under idle. That the fan will not come on. When you shut the car off however the fan will come on untill the engine cools down and the shut off.
    Jul 2007
    2006 350Z 89 Sei 5 speed
    Reading, PA
    Re: Car running hot
    Thermostat switch
    Jan 2007
    Savannah Georgia
    Re: Car running hot
    At the bottom of the radiator? If so should have replaced that too.....
  1. Car running like eh
    By ryan2107 in forum 3geez Accords
    Last Post: 09-05-2007, 03:48 AM
  2. Running car w/o oil
    By maxcrx in forum 3geez Accords
    Last Post: 02-08-2006, 08:59 AM
  3. Running HOT HOT HOT!!@#$#$%
    By xbi0s in forum 3geez Accords
    Last Post: 03-18-2003, 09:43 AM
  4. car not running, need help
    By Cloud892dr in forum Carburetor Tech
    Last Post: 02-11-2003, 03:52 PM
  5. running out of gas
    By baron4406 in forum Carburetor Tech
    Last Post: 10-16-2002, 01:50 PM
