Results 1 to 18 of 18
Thread: how-to double-clutch
    LX User bushbean's Avatar
    Please tell me if the following is the proper way to double-clutch.
    So, I'm driving down the street and need to make a turn.
    I slow down and put my foot down on the clutch and shift into
    neutral. Then, I lift my foot off the clutch and start to put my
    foot on the throttle. While holding down the throttle, I push
    down on clutch and shift into 2nd gear.
    Does double-clutching for up-shifting (e.g., 1-to-2, 2-to-3, etc)
    help prolong the life of the transmission also?
    2ndGenGuy
    Guest
    Re: how-to double-clutch
    Granny shifting, not double clutching like you should...
    Double-clutching, I can't see doing anything on a transmission like ours since we have syncros. I thought that double clutching helped transmissions sync gears that didn't have syncros. I don't think it's applies anymore.
    If you're not careful though, you might blow the welds on the intake manifold.
    http://en.wikipedia.org/wiki/Double_clutch
    read my fellow grasshopper.
    Yea i don't see why you need to double clutch.
    My transmission has over 200,000 miles on it, and it has never been rebuilt. I need it to last another 200,000 miles. Thus, I'm doing whatever I can to prevent wear and tear. I think it is common knowledge that double-clutching or rev matching reduces wear-n-tear on the transmission, although neither technique is necessary for operation. My hand-foot coordination is not so good, which is probably why I'm still not proficient in the double-clutch technique. I usually just rev-match if I am feeling lazy. However, I'm not sure if rev-matching is as good as double-clutching in reducing wear-n-tear.
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    helps with the nawzzzzz
    i would just change the fluid more often. use honda MTF. it helped me with my syncro problem when i cheaped out and put semi synthetic fluid on it.
    2ndGenGuy
    Guest
    Double clutching MIGHT help reduce wear on the syncros, but I doubt it. Rev-matching definitely will reduce syncro wear. But that's about all. Other than that, just be smooth with your shifts, and don't pull high-rpm pulls or slam on the gas. Driving style will make the biggest impact.
    Feb 2004
    89 accord lxi
    down by the bay
    the only time i double clutch is if i'm cruising along the highway in 5th and i need to pass someone. i'll double clutch, drop it into 3rd and floor it. i don't like to skip a gear on a downshift without bringing the transmission up to speed. for normal downshift i just match revs.
    LX User 87LXiR's Avatar
    87' LX-i (hatchback)=Gone, EG8=Daily
    San Fernando
    Rev matching probobly does reduce wear on the gears, but i think it would reduce the wear on the clutch much more. What i do when down shifting is hold the clutch down, rev to the appropriate rpm and release the clutch.All this done in one fluid motion taking no more than what a standad shift would. I feel as if it does reduce the wear on the clutch significantly.
    No more 3G but that doesn't mean i cant look at yours...
    snoopyloopy's Avatar
    Killa Cali
    yeah, exact opposite of what i do. when i downshift, i slip the clutch into gear until then engine is up to speed then release it. but it also depends on how i'm going and which gear i'm downshifting to.
    u gotta at least rev match if you want quick, smooth shifts double clutching seems like overkill though
    for you it's even more extreme going from accord 5th to teg 3rd
    Sep 2003
    '89 LX
    Virginia
    Quote Originally Posted by snoopyloopy
    Thats a good way to kill your clutch. My philosophy is the less amount of time I spend using the clutch, the longer it will last. So I try to find the fastest way to shift, and rev matching seems like its easier on the clutch and the faster way to shift in the long run. It took me a long time to realize it though.
    03/01/08- 129,000 miles
    10/19/08- 136,000 miles
    Blue 3geez
    10.8.06 Photoshoot
    1.7.07 Photoshoot
    Killa Cali
    yeah, but i figure it's cheaper/easier to replace the clutch than engine or transmission. also, this is my first standard car
    Sep 2003
    '89 LX
    Virginia
    Right, but revmatching is also easier on your transmission than what you're doing. Also, I would think the way your downshifting is hard on your motor mounts too. But I dunno, thats just a possibility.
    Blue 3geez
    10.8.06 Photoshoot
    1.7.07 Photoshoot
    DUDE....i had a dream last night that my clutch was giving out. i think its a sign to replace it...haha
    Quote Originally Posted by 87LXiR
    That is what i do as well. I just push the clutch in, put in a lower gear, give gas and let go of the clutch. One way i find it to know if you matched the rev is if the car jolts forward or not. You shouldn't notice the transition, only thing you should notice is RPMs going up.
  1. double posts ?
    By A18A in forum 3geez News & Site Feedback
    Last Post: 09-02-2006, 08:27 AM
  2. double the horsepower
    By 81 accord in forum 1geez Tech & Performance
    Last Post: 06-08-2006, 10:17 PM
  3. Double Clutching
    By My 89 Accord Lxi in forum Performance
    Last Post: 09-02-2003, 06:04 PM
  4. Double Gasketing
    By 1989se-i in forum Performance
    Last Post: 10-13-2002, 12:40 AM
