How is the EGR, replace it or just clean it out? Replacing the O2 sensor(s) might cure the rich A/F issue. Make sure your manifold vacuum is at 20 inches. MAP sensor voltages are less than 1.0 volt when the engine is idling at sea level. If the MAP sensor voltage is higher than 1.0 volt, the engine has low manifold that will result in a rich mixture.
Fuel injectors- Connect a fuel pressure gauge, start the engine. Turn off the engine, slowly & carefully pinch the return hose, & check the fuel pressure leak down rate. If the fuel pressure decreases more than 10 psi in 30 minutes, an injector is leaking causing a rich mixture.
Catalytic Converter- Since your in California, you'll need good catalyst. You'll need a monolithic one, which is coated with catalyst agent on a ceramic honeycomb material. If your talking about a high flow cat you get off ebay, that is basically a glorified test pipe.
