Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 136
Thread: SZfiftyfour's 2G Accord Restoration
    LXi User SZfiftyfour's Avatar
    '82 Accord DX Sdn
    Ocala, FL.
    Original thread
    https://www.3geez.com/forum/showthread.php?t=61140
    New stuff
    There's not much updating going on here though. It's been raining almost every day lately.
    But I did manage to install some ACCEL super stock 8mm wires and a super stock performance coil. Waiting on my iridium plugs to come in. Also found out my dizzy cap is worn out. Getting that in tomorrow too.
    Coil
    Re: Ccord's updates
    Very Nice!
    note to self look at 2geez more offton
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Re: Ccord's updates
    Nice clean engine bay!
    Re: Ccord's updates
    nice and shiny!
    2ndGenGuy
    Guest
    Re: Ccord's updates
    Man, how'd I miss this thread? Good work keeping that EK1 in tip top tune!
    Ichiban's Avatar
    North of You.
    Re: Ccord's updates
    My engine is filthy and the distributer cap is smashed somehow, but it still runs. Hopefully the new one shows up before I leave for Red Deer again tomorrow.
    ICHIBAN!
    "Now, even more better!"
    LX User xvok's Avatar
    83 accord honda hatch
    olympia WA
    Re: Ccord's updates
    ek1' unite
    Re: Ccord's updates
    tasty......
    '82 Accord DX Sdn
    Ocala, FL.
    Re: Ccord's updates
    thanks to all, for the comments! i must have got it's good side, cuz the rest of the bay is pretty grungy. planning on getting that mess kleend up one day.
    '82 Accord DX Sdn
    Ocala, FL.
    Re: Ccord's updates
    Here's a vid of an engine problem i'm having; maybe someone can help me out?
    It stumble's at idle and during deceleration (coasting in gear). There's no problem during acceleration or basically any time the gas pedal is pressed (even just slightly). I didn't notice this before the Weber 32/36 went on. Although the stock carb before it was screwed up and idled high anyway, so it could have been doing it unnoticeably. I've replaced the dist cap/rotor/wires&plugs; So I'm thinking vacuum advance-retard problem/ bad distributor/ idle jets or air correctors wrong/ timing off. The video shows the rpm bounce then the exhaust at idle. The camera's mic picks up a clicking/popping sound from exhaust but its not, those are "puffs" of exhaust.
    http://vids.myspace.com/index.cfm?fu...deoID=18044202
    2ndGenGuy
    Guest
    Re: Ccord's updates
    Have you gone through the Weber Lean-Best Idle process? There is a PDF out there on the intarwebs which will really help you get your car running smoothly.
    I would follow this guide EXACTLY. I had some similar problems to what you're having and this guide really helped me tune it out.
    http://www.redlineweber.com/html/Tec...lean_best_.htm
    If you're still having problems, likely you need to rejet. In order to get your carb really running right EVERYTHING else must be good first. Mainly, just make sure your timing is set up to the best of your ability, and it sounds like you're good to go with the new plugs and wires.
    '82 Accord DX Sdn
    Ocala, FL.
    Re: Ccord's updates
    Thanks for the info!
    That diagram came with my kit and i thought i did the lean-best idle exactly like it said, but maybe not. I'll check that again too. Might be getting the 4cyl jet kit from the same place because i know the air corrector is off. there's a hard shift from primary to seconary opening, like a flat spot or it boggs down for a sec. somethings not setup right.
    I been meaning to check the timing but been working too much lately. Im off this weekend maybe i'll get something done.
    Ichiban's Avatar
    North of You.
    Re: Ccord's updates
    Your car reeks of vacuum leak...how does it smell?
    ICHIBAN!
    '82 Accord DX Sdn
    Ocala, FL.
    Re: Ccord's updates
    Quote Originally Posted by guyhatesmycar View Post
    You're right, it is a vac leak. The advance wouldn't hold vacuum when I tested it.
    '82 Accord DX Sdn
    Ocala, FL.
    Re: Ccord's updates
    I finally got around to refreshing my bumpers and trim.
    Before pics:
    Deconstucted for cleaning:
    After pics:
    In the process I broke just about every one of those stupid plastic
    trim tabs. Considering they're 25yrs old I figured I would. I went to
    the parts store and got some similar sized ones. Hopefully they work.
    SEi User knarg's Avatar
    '04 Forester 2.5XT
    Fort Collins, CO
    Re: Ccord's updates
    wow looks really good, i like the body color
    2ndGenGuy
    Guest
    Re: Ccord's updates
    Lookin' good! Those faded bumpers make such a huge difference. Makes the whole car look new!
    '82 Accord DX Sdn
    Ocala, FL.
    Re: Ccord's updates
    Thanks, I like the color too especially with the cream interior.
    '82 Accord DX Sdn
    Ocala, FL.
    Re: Ccord's updates
    thanks man, I was thinking of putting 2.5g bumpers F&R on it so i can color match them. Im wondering if the mounting points will be different though.
    Re: Ccord's updates
    Looks a lot better
    As for 2.5g bumper, I don't know about the mounting points, but locals do that all the time, so I assume it won't be much problem.
    2ndGenGuy
    Guest
    Re: Ccord's updates
    Quote Originally Posted by CcordLevel2 View Post
    Yeah, it's not going to be a direct bolt-on I get the feeling. But I always wanted to see how those cars would look with the later bumpers! Like Hazwan says, it shouldn't be a huge problem.
    '82 Accord DX Sdn
    Ocala, FL.
    Unhappy Dammit.
    Some loser backed into my car while I was at work. Not sure when, its barely noticable and I didn't realize until the other day i opened the trunk and it acted weird.
    I bent it back as strait as i could but then the trunk wouldn't close. So i had to bend the latch-hook back to where it was supposed to be and it closed but not like it used to. At least they didn't leave any marks or scratches.
    [excuse the dirt; my car's ready for bath]
    Trunk doesn't line up straight anymore.
    2ndGenGuy
    Guest
    Re: Ccord's updates
    Man people are dicks. After my fresh repaint, I would park way at the back of the lot, and some douchebag would always park right next to me when there were like 50 open spots. My car is riddled with door dings now. And its the people who hit you and assume that because it's some old Honda that it's no big deal. Not even the courtesy to leave a note. Man that pisses me off the lack of respect people have for other's property...
    '82 Accord DX Sdn
    Ocala, FL.
    Re: Ccord's updates
    I know, right. If everyone was a car guy/gal we wouldn't have this problem.
    Re: Ccord's updates
    damn... sounds like ocala for you.... some dick allways seems to hit someones car while its not moveing , sucks man, if you need a hand working on it trying to straighten it out let me know... i leave for the airport in like 3 hours to fly into orlando
  1. Stezie's - 1988 Accord 2.0i 16v - OEM Restoration
    By stezie in forum Classic Honda Pics & Videos
    Last Post: 04-24-2019, 01:28 AM
  2. Heat gun restoration
    By nswst8 in forum Interior & Exterior Care
    Last Post: 12-27-2009, 09:35 PM
  3. 1977 Accord Restoration
    By carver in forum 1geez Accords
    Last Post: 01-31-2009, 06:31 AM
  4. Seeking Seat Cover Fabric--Mauve Red--For 1986 Accord LXi Restoration
    By Raphael in forum Interior & Exterior Care
    Last Post: 04-25-2007, 01:07 PM
  5. Suspension Restoration
    By 86-accord-lxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-28-2006, 01:11 PM
VigLink badge
