Looks like everyone is finally warming up to the older generations. Congratulations to 2ndGenGuy for becoming our first 2G AOM winner!
2ndGenGuy
Engine:
Weber 32/36 Carb Swap
Complete Vacuum & Emissions Removal
EGR & Air Suction Removal
DC Sports Header
High Flow Cat
Custom 2.25 Inch Cat-Back Exhaust
Magnaflow Muffler
MSD Blaster 2 Coil
Accel SuperStock DIY Plug Wires
NGK OE Plugs (not really a mod, but good plugs )
2g Prelude Transmission Swap
Clutchnet 9lb Flywheel & OE-style Clutch
Suspension and Brakes:
Koni Reds Front
Koni "Yellows" Rear
Eibach ProKit Springs
Brembo OE Drilled/Slotted Rotors Front
Prelude Rear Disc Swap w/ Drilled/Slotted Rotors
Yokohama YK420 Tires
Interior:
Uber-Rare JDM Armrest
Uber-Rare center console
Integrated 120Volt Power Inverter
Integrated RCA Line-in jacks
Blue LED Backlit Gauges w/ White Needles & Analog Clock Swap
Blue Neon Floor Lighting
Blue LED Puddle Lights & Dome Light
Blue Neon Trunk Lighting
3rd Gen Steering Wheel w/ Black Column
3rd Gen Shifter Boot and Knob
Exterior:
Complete Rust Removal and Newer Paint & Bodywork (2002)
Welded Trunk Badge Holes (Debadged)
Acura Integra GSR "Fat Fives"
1.3-1.5 Inch Drop
Drilled & Slotted Rotors w/ Red Calipers (Visual Upgrade)
eBay H4 Low-beam conversion
Full LED signal lighting
LED "Ultra-white" license plate lights
