Page 2 of 11 FirstFirst 123456 ... LastLast
Results 26 to 50 of 273
Thread: Labeledsk8r's 89 LX-i coupe update thread
    Re: Labeledsk8r's 89 LX-i coupe update thread
    A18a and AccordB20a I was wondering what the... the other day I was going to reply to something one of you said but it was the other one.. the dam sigs mind fuck trick.. lol I just realized it when you posted side by side..im kinda slow huh
    haha yeah i noticed that a few days ago and made this but never used it XD
    Vanilla Sky's Avatar
    1999 Penalty Box
    Hey, the party does start Friday night if you wanted to make it up. There's not a whole lot going on, but hey, I'm always down for a street party.
    well i just got this message and its 4:40 on friday i want to set up a day to drive out there but my accord cant make the far trip might have ot take my girls civic
    1999 Penalty Box
    That's cool, I know how it is to do stuff on short notice. Usually is something you want to do, but can't get everything in line to be able.
    looking good my friend looking good
    LXi User SZfiftyfour's Avatar
    '82 Accord DX Sdn
    Ocala, FL.
    Very nice. Where you get the steel lines?
    Quote Originally Posted by CcordLevel2 View Post
    He got them from me
    but they sell them on ebay
    yeah lol
    thanks
    thanks and i got them from forrest lol
  9. #34
    well a little update...
    the car has been giveing me full hell... i have a large list of things to fix that included all new suspention bushings, oil leaks, power stearing, new rims/ tires (old rims are bent and tires are messed up from no alignment) but some more things went rong that im rushing to fix..
    the driver side power window for some reason went screwy and keeps trying to role down when allready down... i ended up putting another old set in there to keep the window up. also after haveing a starting problem (wich ended up being the battery) i found out my injectors are leaking like crazy, so i orderd some injector seal kits from napa. and lastly i had a bad rattle from doing the brakes figured out my brake caliper holder was worn out and causeing the rattle so i replaced it today and allso threw some new terminals on the batt
  10. #35
    cool sounds like ur bringing the coupe back up to a good car
  11. #36
    i did the injector seals yesterday since they were leaking like hell
    the injectors look old but i just cleaned them since i cant afford injectors right now
    also got some carbon build up out of the intake mani...
    next on my list is going to be to start fixing oil leaks, full suspention bushings, alignment, new rims/tires
  12. #37
    Yay
    Looking good man.
    Looking good man.
    thanks
    well i have yet another problem the car seems to kill its batt in under a day if the car is not ran. i dont even know were ot start to look for the problem... i might install a killswitch just as a cheep temp fix but dunno... anyone have any ideas on what could be draining the battery
  15. #40
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    my first guess for excessive draw on a battery is always the radio. yank the fuse for the radio one night and see if the battery level is any better.
    Don't forget though, if the alternator is dead, or even just terribly weak, your battery will not 'hold' a charge. Bust out the volt-meter, and make sure you're somewhere between 11.5 and 13 with the car off. Then turn it on and hold the rpm's over 2000-2500 and you should be reading above 13.8 (ideally more like 14.1+). If you're not seeing a change in volts, replace that alternator.
    -Mark D.
  16. #41
    thanks
    for drains...
    check brake lights sticking, trunk light, and glove box light,
    I had the brake lights stick for one reason or another on both my 3gens
  17. #42
    Ditto what roodoo said, when I got my 3gee, the brake lights stuck as well. But yeah definitely check the alternator, because in some cases even if it isnt weak or dead it can drain the battery instead of charge it.
    Washington
    Looking Sweet...and like CAH said your car is peeing
    it must be a chick car. it pisses like a chick
  19. #44
    well i woulda updated yesterday but 3geez was down..... i got the batt charged and took it down to autozone to get the alt tested... it came back good as well as the batt.. there dignostic tool said that there was a batt pull with the key off.. so i went back and put a test light between the positive cable and the pos terminal... watching for the light to dim with a fuse pulled... well it went dim when i pulled fuse #4 from the underhood fusebox wich is horn and setbelt motors.... i havent tried anything under the dash yet though...
    and on the taillight thing i just redid the brake light switch becuse they used ot stay on at all times but that was fixed
  20. #45
    no ideas on fuse #4? or the power drain?? havent tried the radio yet im trying the #4 first
  21. #46
    Jul 2002
    Newtown, CT
    what the hell does #4 operate? I don't have my service manual in front of me right now. ...anyone?
    -Mark D.
  22. #47
    when i unpluged the fuse before heading to bed tonight i noticed that i can hear a click in the door like a relay or something... i know theres motors on the seatbelts could they be messing up (and what the hell are the motors on the belts for anyways i know the sedan didnt have it)
  23. #48
    1999 Penalty Box
    Lockup, that's what the motors are for.
    The power window controller is also in there.
  24. #49
    true well the window controler is on a difrent cuircut so its sometihng ot do with the lock up motor i think
  25. #50
    ok well still no idea on fuse #4 so i just pull it nightly...
    heres a positive update
    painted my valve cover (didnt feel like sanding the raised parts, and its a red color the flash made it look orange) also changed my valve cover seal valve cover gromets, cam shaft seal, and dizzy o-ring... so that should help some of the engines leaks
    now for a bad update.... the car wouldnt start for a while today... hapend twice... engine light came on and it wouldnt start... 30 minutes later it started but it keeps haveing this problem.. the check engine light buzzes when it comes on or off...i will check the code next time it happens
  1. RedAztec's Update Thread
    By redaztec in forum Classic Honda Pics & Videos
    Last Post: 08-04-2020, 04:41 AM
  2. Naf's Update thread
  3. Bu's New Acco Update Thread.. (no 56k)
    By jigga89SEi in forum Classic Honda Pics & Videos
    Last Post: 11-10-2008, 10:02 PM
  5. An Update thread
