Results 1 to 25 of 25
Thread: Front suspension bushing overhaul
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    Alright guys. The name speaks for itself, I need to replace almost every bushing down there. LCA bushings, sway bar bushings, etc. etc. I found the sway bar end links that work for us, but thats about it. I'd like to go with Energy bushings for as much of it as I can. Anyone have any links/part #'s? Thanks
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Front suspension bushing overhaul
    Re: Prothane Suspension Bushings
    alright i found all the bushings that prothane offers us:
    front strut rod bushing kit
    8-1201 - 11.39
    front end link kit
    8-401 - 12.39
    front lower control arm bushing kit
    8-210 - 20.39
    front lower shock bushing
    8-907 - 15.39
    There's others as well like the sway bar to frame bushings, but I can't remember everything that I used. I wound up cross-referencing stock bushings on thehondapartsstore.com to find which were also used on the civics. You can replace every bushing in the front with poly except the UCAs. There's also a few in the rear.
    CARDONE SUCKS.
    Apr 2008
    '88 civic wagon
    SoCal
    Awesome. Thanks LX, I really appreciate it. Ill be ordering those tonight
    awesome! thanks for posting that man i need to replace my bushings badly lol
    Sep 2006
    Tucson, AZ
    Sway Bar mount kit:
    Energy Suspension 9-5126 (Requires grinding of brackets to fit to frame, but fits.)
    Shifter bushings:
    Energy Suspension 16-1101
    You have something to press the LCA bushings out? Some have luck burning them out. I first drilled the rubber out, knocked out the center, cut the shell with a sawzall, and then drove what was left out with a punch. Now I have a press. The poly bushings are then easily installed, followed by the pin.
    CARDONE SUCKS.
    i had to use my uncles press to push mine out...i really didnt notice a difference since my stock bushings were still good. at least i know that my bushings will not rot. also make sure to get an alignment.
    Washington
    Quote Originally Posted by LX-incredible View Post
    where did you order yours from? If you come across your oreder reciept could you post up the list of all bushings ordered. Thanks mike
    Washington
    http://www.jegs.com/webapp/wcs/store...OrderCalculate
    if the link works that my order so far. The only thin I found not on the list was the rear control arm bushings part 8-312 $84.99
    Sep 2006
    Tucson, AZ
    Those rear control arm bushings WILL NOT work on our control arms. They are for the 90-93 Accords. They DO NOT fit as lower shock bushings in the rear spindles.
    Quote Originally Posted by mykwikcoupe View Post
    CARDONE SUCKS.
    Sep 2006
    Tucson, AZ
    Front upper strut mount Kit:
    Prothane 8-901 (Includes lower shock bushing for 88-00 civic/integra. The bushing is the same diameter as the accord lower shock bushings, but is a little short. It could probably be made to work with a longer dowel and a gap between the two halves. Not sure if I'd trust it though. You could always pass them to your buddy with a civic. )
    CARDONE SUCKS.
    Sep 2006
    Tucson, AZ
    Those rear control arm bushings WILL NOT work on our control arms. They are for the 90-93 Accords. They will however fit as lower shock bushings in the rear spindles. You can sell the other 6 that come with the kit, or just buy 2 from someone else.
    I had a closer look at the rear control arm bushings and am 100% positive that they will fit our control arms with a thinner sleeve. I have ordered some 1-1/4" OD x 1.120" ID x .065" Wall steel tube and will let you all know how it goes.
    CARDONE SUCKS.
    Sep 2006
    Tucson, AZ
    Resleeving didn't work, I found a sleeve that would press in, but it's a bitch and getting a little thin for my liking.
    I'll tell you what will work though. 2 88-00 Civic rear upper control arm bushing kits (8-307) + the inner sleeves from the 90-97 or 86-89 Accord rear lower control arm bushing kit (8-312). Seems like quite a bit to spend to get poly rear LCA bushings, but if you screwed up and bought the "86-89" Accord rear bushings, you're 1/3 of the way there.
    CARDONE SUCKS.
    Sep 2006
    Tucson, AZ
    This is not correct. I forget what genius started this rumor but they are much too small for the rear shock bushings. There has to be at least 20 people on here who bought a set of them, I can't believe that I'm the first to attempt an install. What works is 8-904 (RR SHOCK BUSH UP/LWR 96-00 CIVIC) The upper bushings fit perfectly in the front so none of the kit goes to waste.
    Mike (mykwikcoupe), I believe I owe you a refund on the set I sold you with the coilovers. pm me.
    CARDONE SUCKS.
    Apr 2008
    '88 civic wagon
    SoCal
    Glad this thread got bumped. Useful part numbers in here.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Legend_master started that "rumor". They are a bit small but they have worked great for him so far.
    '89 SE-i Coupe
    Awaiting Garage
    2drSE-i's Avatar
    Oklahoma City
    Oh and were does the Upper shock bushing go?
    '89 SE-i Coupe
    Awaiting Garage
    Sep 2006
    Tucson, AZ
    I just don't see the point of replacing the rubber with poly if you're going to let the sleeve slop around in the spindle. God the rattling would get to me. If legend-master's spindles have 1/16" of rust in the hole for the bushing he might be fine, other than that they aren't going to work. Trust me, you can drop the damn sleeves through.
    Use the kit I mentioned in my previous post, it's an exact fit, less than half the price, and nothing goes unused. The upper shock bushings that come with the kit work in the front strut mounts.
    CARDONE SUCKS.
    LX User phillie's Avatar
    Hot ASS AZ.
    Bump for reference.
    Hot ASS AZ.
    Made a mistake on part names. Got it.
    The TRW replacement ones are very hard.
    https://www.3geez.com/forum/showthrea...t+rod+bushings
    ^^ so true i notice a big difference when i did mine...Before i used to hit the gas felt like a jurk on one side so i look...there where both blown out...it looks easy but it wasnt
    Jan 2012
    Bump. Will the complete kit, Part #8-2009, work? If you just bought another upper control arm kit, and an extra lower control arm bushing kit?
    ^^ bump for this same question.
    Dec 2003
    Millington, TN
    No, go with what LX-Incredible has listed. It's what I went with and it all worked fine.
    Prothane 8-904 / 8-1201 / 8-401 / 8-210 / 8-907
    Most of the others in that kit will not work.
    Phil
    I've been running these rear bushing for over 10,000+ miles. No noises, they do not move around at all. Did you actually install them and drive around, or is this an assumption? I would not not tell people about the shock bushings if they didn't work.
  1. Suspension overhaul questions
    By 89GhostLxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-12-2012, 03:20 PM
  2. Question: Front LCA outer bushing change
    By 4literranger485 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-04-2010, 06:50 PM
  3. Suspension overhaul but.............
    By AC439 in forum 3geez Accords
    Last Post: 12-24-2008, 10:25 AM
  4. Front Control Arm Bushing replacement
    By '89AccordLX(Rus) in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-01-2006, 06:38 AM
  5. Front lower arm bushing choice
    Last Post: 03-29-2005, 06:39 PM
