Results 1 to 25 of 50
Thread: Forged Internals and B18 intake
    DX User God's Avatar
    Sep 2008
    Rapid City, SD
    Is there any companys that make forged internals for the A20 im thinkin bout doin a t3/t4 wit bout 14psi and a 75 wet shot of ZEX im looking for pistons and rods and maybe a crank if the stock one wont hold up also would i be able to make a adaptor plate to put a B18 intake manifold on the A20 that way i can do aftermarket fuel rail and throtle body from skunk2 also what are my options for tuning is the a Standalone EMS or piggybacks or could i jus do a megasquirt or somethin
    LXi User SZfiftyfour's Avatar
    '82 Accord DX Sdn
    Ocala, FL.
    Re: Forged Internals and B18 intake
    couldn't you make them..... out of dust or something? You could call it the omegasquirt, that'd be cool.
    2ndGenGuy
    Guest
    I dunno man, he kinda fucked up on the 6th day. We didn't turn out all that great. I dunno if I'd trust him to build an Omegasquirt system if he can't even do a good job making us in his image... Maybe he'd be better off buying something pre-made.
    '82 Accord DX Sdn
    Ocala, FL.
    hhrrmm maybe your right.
    Find this god:
    BTW i seen the ninja-edit. i was gonna say.... he rested on the 7th lmao
    2ndGenGuy
    Guest
    Yeah I had to Google it to be sure... Don't strike me down plz god? kthx.
    Maybe this:
    It does look kinda different on a Mac. Much prettier if you ask me...
    f*cking {God} has a fu*cking Honda? fu*k me
    figured he could pick up a ride at Zues Lexus
    heavanly farter please dont think you are going to squirt, turbo on a custom made rotating assembly and not have spent $$ you could have Zues hook you up something you will have more time to make mermaids for us.
    twenty Hail Mary's
    and pardon me, your SN is sacreligious
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    alright i feel helpful sort of.
    1. nobody makes forged internals for the a20.
    2. you have options. LS integra rods will work if you have a custom piston (see next bullet) made with 21mm wrist pin.
    3. diamond will custom make you some bad ass pistons. just have to call them up and do some legwork.
    4. don't know of any special a20 cranks, but you could get yours cryo treated, if you just do the one part it won't be that much money. benefits are arguable.
    5. you don't need an adapter plate to run b16/typer manifold, just a drill and a die grinder...
    6. once you mod the manifold you can automatically use the B series fuel rails, throttle bodies, etc etc...
    7. you have lots of options from tuning, the more you are willing to spend, the more control you will have. cheapest being SAFC and BTM, next up probably an OBD1 conversion or mega squirt depending on how crafty you are. or you could go full standalone, or the plug and play AEM EMS once you are obd1.
    if you have any specific questions just ask us.
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    there are all your answers... check out hs build while your at it, this guy is awesome!!
    -Gio
    My E85 Turbo Build
    5280FEST
    Sep 2008
    Rapid City, SD
    so pretty much your my hero... what all would i have to do to convert it to obd1 and what car would i order the ams ems for and also where did you get you delta 282 cam
    Ichiban's Avatar
    North of You.
    If I blow my brains out all over the ceiling, do I go straight to hell?
    ICHIBAN!
    "Now, even more better!"
    Sep 2008
    Rapid City, SD
    Quote Originally Posted by guyhatesmycar View Post
    only if you have kicked a old lady because she had a gucci purse and you were jealous
    bobafett's Avatar
    Longview, WA
    there is a comprehensive guide to obd1 conversion on this forum... just do a search - https://www.3geez.com/forum/showthrea...nversion+guide
    don't know which aem ems you will need. guanabo89 should be able to help with that.
    http://aempower.com/ViewCategory.aspx?CategoryID=62
    http://aempower.com/ViewCategory.aspx?CategoryID=63
    those are a couple places to start looking
    you can only buy delta cams from www.deltacams.com, they cost around $115 without a core to send them. and they shipped next day... prices have probably gone up a bit.
    also i don't reccomend a 282 for a turbo build. talk to them about a hybrid 262/272 or 272/282 cam for a turbo setup.
    He did tell his disciples to be in one Accord...
    Sep 2008
    Rapid City, SD
    how come you dont think i should go wit a 282 cam for a turbo also i was thinkin bout gettin my ZEX kit and jus puttin some lower jets in like a 35shot or somethin till i can have the motor pulled to be buildt would i be able to get away with this or is that too much for a stock A20... also i did have a ? wit a short ram intake the stock intake comes off the throtle body then wraps around to the filter and then has that long pipe on it well there is a box with vacume hoses coming off of it wat do i do with that when i install a short ram intake
    Ichiban's Avatar
    North of You.
    Quote Originally Posted by God View Post
    TOOO much overlap between lobes. Intake charge goes straight out the exhaust. Scavenging is great for a N/A setup, not so much with forced induction.
    I like my gucci purse, and I like kicking old ladies. Where's the problem?
    ICHIBAN!
    Sep 2008
    Rapid City, SD
    well im glad you like your purse and everyone needs a hobby i guess yours is kicking old ladies lol....
    so the 272/282 hybrid would be good for a turbo then and also wat bout that 35 shot on a stock bottom end????
    2ndGenGuy
    Guest
    If the bottom end can't handle 35hp via Nitrous, it woudln't handle boost so well either. I think a 35 shot would be fine. Probably get away with a 50 shot for a while I'd bet.
    Sep 2008
    Rapid City, SD
    yea after i said a 35 shot zex i seen the smallest injectors they offer is a 55 might have to go wit a NOS or Venom Kit not sure though im jus lookin to get a few extra ponies outta her before a do my hopeful 325-350whp A20 + 75shot NOS if that dont get me into the 12's i will personally drive the car into a lake
    LX User evil88accordLX's Avatar
    Jul 2007
    gold 88 accord lx
    NWA (not the rap group)
    13 dudes in one Accord.....have to be a stretch Aerodeck or some shit.
    bobafett's Avatar
    Longview, WA
    I think a 35-55 shot is fine as long as it is setup properly. Boost will add a lot more power than that if you do it right! The bottom ends are okay in these motors, but the weakness is we have no easy way to tune them.
    Even the 272/282 hybrid is a bit sketchy imo for turbo setup. I haven't heard any results of people using non-stock cams for boosted setups. I feel like a 272 would be okay possibly, but having had a 282 in my car I wouldn't want that on the turbo setup. you just overlap your power away! like was mentioned above.
    2ndGenGuy
    Guest
    "God woudln't be up this late..."
    Quote Originally Posted by evil88accordLX View Post
    or they all have to be mexican lol
    wait a second, can you say H E double hockey sticks ? here's yur sign
    Looks like the heavanly farter has done some homework.
    89T's Avatar
    Apr 2004
    i doubt you'll pull 325-350hp on 14 psi.......
    you may be able to get that with 14 psi + 100 shot.
    or possibly 20 psi and a 50 shot.
    figures taken from banks turbo.
    figure n/a hp + 8% gain per pound of boost.
    say 100hp n/a = 8hp per psi
    8hp X 14psi = 112hp
    112hp + 100hp = 212hp
    i have compared figures with my dyno sheet and the figures were within 2 hp.
    at the same 100hp
    8hp x 25psi = 200hp
    200hp + 100hp = 300hp
    if you pull 350hp on 14psi without nitrous you would be god! lol!
  1. 2g lude Internals in a 3g accord
    By FoX in forum 3geez Accords
    Last Post: 02-01-2007, 03:01 PM
  2. Want to do Internals, but Not pulling engine
    By JFreddy in forum Performance
    Last Post: 07-06-2006, 10:03 PM
  3. Engine BLock and Internals (56K get owned)
    By smufguy in forum Classic Honda Pics & Videos
    Last Post: 02-14-2005, 10:36 AM
  4. Civic D16Y8 internals...
    By AccordEpicenter in forum Trading Post
    Last Post: 12-14-2003, 11:28 PM
  5. List of internals
    By goldyaccord in forum Performance
    Last Post: 05-13-2003, 04:26 PM
