Results 1 to 16 of 16
Thread: Need your healp(Again)LoL(Tires)
    LXi User headbanger's Avatar
    Dec 2007
    1989 accord lxi
    waynesville,nc
    Hi could some1 tell me if 205/55/16 tires will fit on my accord without rubbing.
    Thx in advance.
    Sep 2003
    '89 LX
    Virginia
    Re: Need your help(Again)LoL(Tires)
    Quote Originally Posted by headbanger View Post
    Thx in advance.My computer messed up an posted twice sry for the clutter my bad.
    Is your car lowered? The recommended size for 16" wheels is 205/45/16, I don't think your car would rub but then again I have no experience with a tire 10mm taller than it's supposed to be.
    03/01/08- 129,000 miles
    10/19/08- 136,000 miles
    Blue 3geez
    10.8.06 Photoshoot
    1.7.07 Photoshoot
    i thihk i have a 205- 50-16 in the rear and i dont rub and im like at least 2 1/2 inch drop in the rear lol
    Dec 2007
    1989 accord lxi
    waynesville,nc
    I wanted to make sure be4 I bought some Im running 205/40/16 an when I hit a bump there is just not enough cushion between tire an road I actually broke a rim while back I hit a little rock in the road I had to get wheel rewelded back.Finally getting ready to put them back on miss my rims lol.thx 4 the help
    Dec 2007
    1989 accord lxi
    waynesville,nc
    Quote Originally Posted by Toneloc5145 View Post
    no it is not lowered.
    Sep 2003
    '89 LX
    Virginia
    You SHOULD be fine, based off of the fact that your not lowered....this in theory. You also need to take into account the offset of your wheels, how healthy your shocks and springs are (whether they sag/ dampen poorly). I have 205/50/15 tires with 33 offset wheels and I rub on bumps/sharp turns with 1 or more people in the back seat. With my 17" rims (205/40/17 40 offset), I don't rub at all.
    Blue 3geez
    10.8.06 Photoshoot
    1.7.07 Photoshoot
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    Re: Need your healp(Again)LoL(Tires)
    Personally, i think 55 might be a bit too big. Don't forget that it's not just a matter of rubbing or if they'll "fit". Think of your tire/wheel as your last 'gear' in the whole equation. Changing the overall diameter of the wheel/tire combo will throw off your speedometer, and may offer a different 'feel' beyond that of just the comfort level.
    The last bit of info that we do need is what your offset is on your wheels. As Toneloc said, his 205/50/15's rub, but that's not because of the tire, but instead because of the 33 offset. His 205/40/17's are damn near the exact same diameter of the 15's and I'm guessing they're a hair wider, but due to the 40 offset, there is no rub.
    Regardless of your offset, if you're running 205/40's now, and you just don't like the harsh ride, bump them up to the recommended 205/45 and you'll notice a great difference. If your offset is between 40 and 42 (you might be able to get away with a 38 also) you can try to squeeze a plus-size of 205/50 on them, and I think you'll be fine.
    -Mark D.
    Dec 2007
    1989 accord lxi
    waynesville,nc
    they are 38 offset.
    Dec 2007
    1989 accord lxi
    waynesville,nc
    Ok thx alot.
    205/50/16 is perfect bro....55 is a bit to much if your lower then 2.5 or even that..
    Rendonlxi
    Dec 2007
    1989 accord lxi
    waynesville,nc
    Rendonlxi
    ok thanks much.
    i run 205-50-16s and i rub on the rear...even after getting an alignment
    did you roll you inner fender...?
    nope but i bet it would make the rubbing go away
    yes it would....i had that same problem...Get a bat and roll the bitch it easy but take your time and dont put to much pressure or ull have the wide body look lol...
    Rendonlxi
    DO NOT ROLL YOUR FENDERS IF YOU HAVE RUST!!! i have learned that the hard way
  1. New Tires
    By Darkside in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-25-2005, 08:36 PM
  2. wtb-new or used 17's tires
    By 87accordHB in forum Trading Post
    Last Post: 08-03-2003, 11:45 AM
  3. tires
    By 'A20A3' in forum 3geez Accords
    Last Post: 05-15-2003, 05:44 PM
  4. best tires on 17s?
    By 89LXIGUY in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-22-2003, 09:08 PM
  5. My New Tires
    By Site in forum Classic Honda Pics & Videos
    Last Post: 09-05-2002, 06:16 AM
