Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 159
Thread: 2ndGenGuy's '81 Hatchback MegaJolt Lite JR Conversion
  1. #76
    Re: 2ndGenGuy's '81 Hatchback MegaJolt Lite JR Conversion
    FTW!!! and that car sounds/runs smoother then mine and its 10 years older :O
  2. #77
    Awesome work there.
  3. #78
    AZ
    i'll have to check htis out on my phone right now and report back my findings
    dead white and blue
  4. #79
    a pile of lawn ornaments
    Newtown, CT
    well shit if that doesn't make me REALLY jealous. Damn you John. ...and congrats on the install and getting it running.
    -Mark D.
  5. #80
    AZ
    watched it, looks good.
    dead white and blue
  6. #81
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Hey man, congrats on getting it running.. didn't take too much time! The little beast sounds great too, now comes the tuning part?
    Andrew.
  7. #82
    Thanks guys! Yeah, after I redo all the wiring, and make a mounting bracket for the coil packs, then I'll take it for a spin and give it a tune. I might install the hard rev limiter first though since it will require me to rewire the coil power back to the MegaJolt unit.
  8. #83
    Newtown, CT
    you should re-wire that MJLJ into a USPS box and ship it my way.
    -Mark D.
  9. #84
    AZ
    lol
    dead white and blue
  10. #85
    cygnus x-1's Avatar
    Chicago area
    Well the tach out on the EDIS does run my tachometer just fine. I used a little starting fluid and the car fired right up!! But it won't fire the fuel pump. I'm going to just bypass the relay for now, since I can't get any diodes tonight. Do you have a picture by chance of how you set up those diodes? Did you put them on a little board in a box or just heat shrink around the diode and put them inline with the wire?
    You can put them on a board but it's kinda overkill. I just soldered the diodes together directly will some wire pigtails to connect to the rest of the wiring. Add lots of heat shrink to make sure nothing shorts out and you're good.
    Now comes the fun part of figuring out a good timing map. Best way to do that is on a brake dyno, but that will cost some money. I could probably reverse engineer a timing map from the stock distributor if I had one to play with. But then that would only get you to stock, not necessarily the best in terms of power.
    C|
  11. #86
    Yeah the timing map is going to be the fun part. I sorta understand how to do the timing under load, advance it until I ping and back it off a few degrees. But what about idle and cruise? Do I still want it advanced as much as possible? I was playing with the idle timing last night, and it seemed smooth anywhere from 14 up to like 20 degrees. I didn't really take it any higher than that, as I just was trying to figure out the operation. But do I want to advance idle up like that as well? Or just go with where it runs best? Sorta like running it by ear? The local shop here will rent out an hour of dyno time for $80 with a sniffer and let me use it as I please. So I can do as much street testing as I can and then hit the dyno and try to squeeze out a bit more.
  12. #87
    Ichiban's Avatar
    North of You.
    That's the coolest thing I've ever seen.
    ICHIBAN!
    "Now, even more better!"
  13. #88
    So awesome John! Your engine sounds sooooo good.
  14. #89
    AZ
    as for the tuning it's really difficult to explain how to street tune, i know a guy that does them really well, obviously better with a dyno, but if you have access to the dyno i'd just work out a map while on it, for 80 bucks it's worth the money in my opinion.
    dead white and blue
  15. #90
    LX User Importordomestic's Avatar
    1988 Accord Hatch
    Hueytown Alabama
    +1 - its easier to see the tq on a load bareing dyno than by seat of the pants. Get the idle really good then tune WOT after that work on part throttle and cruise.
    I tune my idle for best "tip in" throttle response. on a complete efi engine. For a carb i add timeing until it gets hard to crank when the engine is hot, then i back off ~3 degrees. Your mileage may very, and alot of tuners will tune things differently.
    here is a link that should help you with your spark tune -http://www.msextra.com/doc/ms1extra/MS_Extra_Tuning_Manual.htm#sparkmap
    P.S. congrats on your car and running with out a dizzy.
    88 - Hatch - FF class track car Major Upgrades!
    87 - Hatch - DD
    88 rx7 turbo II - FR class track car - blown engine
    86 rx7 NA - Under Construction
    90 240 hatch - SOLD
  16. #91
    That is epic win sir (y)
    LXi User SZfiftyfour's Avatar
    '82 Accord DX Sdn
    Ocala, FL.
    Quote Originally Posted by catalyst View Post
    wow! Awesome! I am impressed!
    Quote Originally Posted by a20a1 View Post
    awesome work there.
    well shit if that doesn't make me really jealous. Damn you john. ...and congrats on the install and getting it running.
    Quote Originally Posted by stat1k View Post
    hey man, congrats on getting it running.. Didn't take too much time! The little beast sounds great too, now comes the tuning part?
    you should re-wire that mjlj into a usps box and ship it my way.
    Quote Originally Posted by ichiban View Post
    that's the coolest thing i've ever seen.
    Quote Originally Posted by dr_snooz View Post
    so awesome john! Your engine sounds sooooo good.
    Quote Originally Posted by hazwan View Post
    that is epic win sir (y)
    ^^ +9
  18. #93
    AZ
    lol +9 ftw! hahaha
    dead white and blue
  19. #94
    cygnus x-1's Avatar
    Chicago area
    The advance 'till it pings and back off strategy works for some engines but not so much for others. Really the best way is to advance until maximum torque, and then stop. Or stop before then if it starts pinging, but that won't happen unless you have higher compression or REALLY crappy fuel.
    I would imagine this engine is similar to the A20 in that it will like lots of advance (because of the not very optimal combustion chamber). Here's a map that pretty close to what I'm running at the moment:
    This is sort of a hybrid between an A18 distributor vs. a P75 ECU. The heavy advance between 1500 and 2000RPM makes for really zippy throttle response. Before you start tweaking the timing do make sure that the timing you set in the map matches what the engine is actually doing. If it's off then you can either adjust the sensor mounting location or just include an offset in the map to compensate.
    C|
  20. #95
    DAMN....John congrats and your ass just came along way from you first joined. YOU gave alot of openings for the 1gees and the guy that did it all was you. COngrats once again and very great work buddy
    Aug 2009
    '13 Honda Civic LX
    Loudonville, NY
    Quote Originally Posted by Catalyst View Post
    Wow! Awesome! I am impressed!
    Quote Originally Posted by A20A1 View Post
    Awesome work there.
    Quote Originally Posted by Ichiban View Post
    Quote Originally Posted by SZfiftyfour View Post
    ^^ +9
    +10 It sounds so nice man full of win I also see in the vids you have the 2d dock, with the transparent menubar disabled, running the graphite color scheme along with windows running in a VM. Yes I have problems that I noticed all that :p
  22. #97
    Quote Originally Posted by Mellexx View Post
    You sir, needs help
    what did he just say LOL
    Aug 2009
    '13 Honda Civic LX
    Loudonville, NY
    You sir, needs help
    Says the guy who cleans hidden parts :p
    noticing pointless details on the mac and confusing Rendon ftw!
    Back to the topic :p this is full of win
  25. #100
    AZ
    lol ^ don't make him too confused he'll go ghetto on your ass!
    dead white and blue
  1. ItzDave's Megajolt thread!
    By itzdave in forum Carburetor Tech
    Last Post: 10-13-2011, 08:22 PM
  2. 2ndGenGuy's new 89 LXi Coupe 5 speed
    Last Post: 01-30-2010, 02:05 PM
  3. Gas lite
    By skinner17 in forum 3geez Accords
    Last Post: 10-26-2009, 06:00 PM
