Results 1 to 15 of 15
Thread: dash removal question
    bridgewater.NS Canada
    Exclamation dash removal question
    Hey guys I have a leak on the drivers side and I'm trying to get the dash out to find it.Do i have to drop the steering column to do it.
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: dash removal question
    if i remember correctly ya dont, but i do think it might make things easier if ya do...
    Well i didn't take off the steering wheel or the cover around ign switch and it catches on top of the column,so thats why i asked.
    DX User Shilo's Avatar
    Jul 2010
    1989 Accord LX, 1976 Nova, 1980 Plymouth TC3, 1985 AMC Eagle
    Virginia
    I just got my dash out today, and you can do it without dropping the steering column. Just be careful when pulling it out so you don't break the plastic piece that goes over top of the column of it like I did............
    it's really easy to drop the entire thing in one piece, why not take it out of the way and make it much eaisier?
    LX User beran24's Avatar
    Apr 2008
    1989 Honda Accord dx 2dr, 1989 exi, 87 hatch
    Nova Scotia Canada
    x2 putting it back in is twice as hard with it in the way its a bitch to tryin lift it up over the wheel and slide it in by yourself with out having it catch up on shit.
    Quote Originally Posted by beran24 View Post
    ?? i mean the entire column, with the wheel and everything on it, a few bolts and it's down. you don't disconnect the entire thing.
    you can either remove the steering wheel, the plastic covers & the combination switch, or remove the few bolts holding the column to the body of the car to drop it, either way takes about the same amount of effort, i personally prefer to just drop the column
    Thanks I'll drop the column,I'm not removing the dash just sliding it back so i can find the leak.
    Well slid the dash back,poured some water over the hinge area.Water poured in through the pinch welded area above the vent.Don't know where its coming from outside as i can't find a hole.Any suggestions would be helpful.
    ^ Door seal. Any weak/missing areas?
    make sure the rubber corners at the bottom of the drip rails are in place. they are at the back of the cowl cover, they take the water from the roof rails and move it through the drains. if they are missing, water will run down the edge of the door and leak. also take simple green and clean the rubber seals really good. it works trust me, i'm not sure why but it works
    All the rubber seals and cowl are removed to work on the car,i mixed up some resin and hardener and poured it on the area behind the hinge and i think that did it.I have never had one of these cars that didn't leak on the drivers side or passengers side,they just seem to like to rust there.
    Well i went to move the car today but when i started it up the right signal light was flashing and the lever was off.Also when i tried to put it in gear it wouldn't even with my foot on the brake.Plus couldn't get the key out til i took the ground off the battery.What did i hook up wrong or forget to plug in when i had the fuse box unplugged.Can anyone help please.
    Got it fixed,went over all the connections and all is good.
  1. LXi Ac removal under dash
    By Rendon LX-i in forum Classic Honda Community Chat
    Last Post: 02-26-2011, 05:26 PM
  2. dash removal question
    By acco-R-d in forum Interior & Exterior Care
    Last Post: 08-07-2005, 11:49 AM
  3. in dash tv/dvd question
    By Ludi Mali in forum Interior & Exterior Care
    Last Post: 11-05-2004, 03:34 PM
  4. Dash Question
    By 85accordhatch in forum Interior & Exterior Care
    Last Post: 03-15-2004, 10:20 AM
  5. Dash removal
    By Modemagic in forum 3geez Accords
    Last Post: 03-06-2004, 08:57 PM
