Hey guys I have a leak on the drivers side and I'm trying to get the dash out to find it.Do i have to drop the steering column to do it.
if i remember correctly ya dont, but i do think it might make things easier if ya do...
Well i didn't take off the steering wheel or the cover around ign switch and it catches on top of the column,so thats why i asked.
I just got my dash out today, and you can do it without dropping the steering column. Just be careful when pulling it out so you don't break the plastic piece that goes over top of the column of it like I did............
it's really easy to drop the entire thing in one piece, why not take it out of the way and make it much eaisier?
you can either remove the steering wheel, the plastic covers & the combination switch, or remove the few bolts holding the column to the body of the car to drop it, either way takes about the same amount of effort, i personally prefer to just drop the column
Thanks I'll drop the column,I'm not removing the dash just sliding it back so i can find the leak.
Well slid the dash back,poured some water over the hinge area.Water poured in through the pinch welded area above the vent.Don't know where its coming from outside as i can't find a hole.Any suggestions would be helpful.
^ Door seal. Any weak/missing areas?
make sure the rubber corners at the bottom of the drip rails are in place. they are at the back of the cowl cover, they take the water from the roof rails and move it through the drains. if they are missing, water will run down the edge of the door and leak. also take simple green and clean the rubber seals really good. it works trust me, i'm not sure why but it works
All the rubber seals and cowl are removed to work on the car,i mixed up some resin and hardener and poured it on the area behind the hinge and i think that did it.I have never had one of these cars that didn't leak on the drivers side or passengers side,they just seem to like to rust there.
Well i went to move the car today but when i started it up the right signal light was flashing and the lever was off.Also when i tried to put it in gear it wouldn't even with my foot on the brake.Plus couldn't get the key out til i took the ground off the battery.What did i hook up wrong or forget to plug in when i had the fuse box unplugged.Can anyone help please.
Got it fixed,went over all the connections and all is good.
