Results 1 to 12 of 12
Thread: Cooling Issue
    Oct 2010
    87' Accord Lxi Hatch
    Western Washington
    Cooling Issue
    Hey guys, I'm in need of some 3geez expertise. So here's the problem: When I take my radiator cap off and let the car warm up the coolant flows fine. Both hoses get warm, so I know coolant is getting into the engine. BUT when I warm up the car with the radiator cap on, only the top hose gets hot and the bottom hose stays cold. So, coolant can't make it out of the radiator with the cap on, but can with the cap off. I've bled it correctly, and replaced the cap and thermostat. Any idea what could cause this? Thanks.
    Re: Cooling Issue
    That is pretty much how the cooling system is supposed to work. Hot water goes into the top of the radiator and cools as it falls. When it gets to the bottom, it is returned to the engine for another cycle. The bottom hose should be cold. The system is designed to operate under pressure. Pressure raises the boiling point of the coolant and allows it to cool more effectively. When you remove the cap, it makes the system less efficient so you get both hoses heating up.
    I'm sure this wasn't a theoretical question though. What's going on with your car that you are investigating the cooling system?
    Oct 2010
    Western Washington
    Re: Cooling Issue
    It starts smoking when I sit for a minute or so in traffic, not a lot, just a little bit coming out the hood. Cooling fan never comes on by itself so I hard wired it and keep it on around town, but it still smokes. Plus when it starts to smoke it runs real rough. So because it still seems to overheat even with the fan on, I assume coolant isn't flowing.
    Re: Cooling Issue
    Do you actually smell coolant? Are you losing coolant? The oil seals on these cars like to spring leaks and must be changed every so often. If you're seeing smoke, I would think it's oil before I'd think it's coolant.
    As for overheating, there are a lot of things it could be. Check the coolant level in the radiator first. If the cooling system hasn't been maintained well, then you should get that up to snuff too. Change the coolant and replace the thermostat. Check all your hoses to make sure they aren't leaking. If they are, get them replaced promptly. If you don't, they will eventually explode and you'll be stranded. When that happens, there's a very high likelihood that you'll blow the engine too. That's an expense you don't want. Get that done and if the problem continues, we'll go from there.
    Oct 2010
    Western Washington
    Re: Cooling Issue
    I already did a complete flush so I'm good there, replaced the thermostat and radiator cap, and no the hoses are not leaking. So, on that note, you think the smoke could be oil? How should I go about diagnosing that? Thanks for all your help.
    car6289's Avatar
    Jun 2002
    1989 Honda Accord LX , 2009 Honda Ridgeline & 2005 Honda Civic (1987 Accord LX - RIP)
    Abbotsford, B.C., Canada
    Re: Cooling Issue
    Quote Originally Posted by limikjr View Post
    Heat up some oil until it smokes, take a whiff.
    Heat up some antifreeze/coolant until it smokes, take a whiff.
    You are training your nose to tell the difference in smell between oil smoke and antifreeze/coolant smoke.
    When you determine what is causing the smoke, it narrows down where to look for the leak(s).
    Learn from the mistakes of others. You'll not live long enough to make them all yourself.
    SE-i Sedan 5 spd
    Re: Cooling Issue
    What is the temp gauge doing when all this is going on?
    SE-i Sedan 5 spd
    Re: Cooling Issue
    Also, are you getting smells in the cabin with the ventilation control on "fresh?"
    LXi User SZfiftyfour's Avatar
    '82 Accord DX Sdn
    Ocala, FL.
    Re: Cooling Issue
    Check the air-filter housing for oil. If you have excessive blow-by it would collect in the filter box and drip onto the exhaust. Just one possibility but its super easy to remove it and check.
    Oct 2010
    Western Washington
    Re: Cooling Issue
    Quote Originally Posted by car6289 View Post
    Definitely smells like coolant.
    Quote Originally Posted by w261w261 View Post
    Gauge doesn't move from halfway.
    Sometimes I can smell coolant.
    Quote Originally Posted by SZfiftyfour View Post
    No oil
    So I ran it today and it started smoking from near the top of the engine. Not a lot, just a little. Is it possible it's the head gasket causing a small leak?
    Re: Cooling Issue
    I would look for a leaking hose or thermostat cover before considering other more expensive alternatives.
    car6289's Avatar
    Jun 2002
    Re: Cooling Issue
    Get the cooling system pressure tested.
    In the same area as the thermostat cover is the thermostat housing to head "D" shaped o-ring. If you haven't discovered already, most of the rubber seals on or near the engine harden with age and heat. Once hardened the seals stop sealing and start leaking.
  1. Cooling fan issue.
    By jpetrovic in forum 3geez Accords
    Last Post: 11-22-2008, 11:47 PM
  2. random cooling fan issue, my car is posessed !
    By 86-accord-lxi in forum 3geez Accords
    Last Post: 12-03-2007, 08:20 PM
  3. Replies: 19
    Last Post: 01-15-2007, 04:12 PM
  4. Hot Day + A/C + Cooling
    By mindlos in forum 3geez Accords
    Last Post: 07-07-2004, 07:29 PM
  5. Cooling fan/s never off!!!
    By blahblahblah in forum 3geez Accords
    Last Post: 05-24-2004, 03:32 PM
