Results 1 to 10 of 10
Thread: Car feels like its flooding or misfiring when i...
    DX User Dirt Nasty's Avatar
    Apr 2009
    1988.Accord.LXi 5sp.
    The south end, 206
    So anyways my car feels like its either flooding, or misfiring a cyl. or two, WOT only.. Idle seems fine and i think it mostly happens in the 1k to 2500rpm range.. Timing adj. maybe?
    Need some advice pls.
    DX User Shilo's Avatar
    Jul 2010
    1989 Accord LX, 1976 Nova, 1980 Plymouth TC3, 1985 AMC Eagle
    Virginia
    Re: Car feels like its flooding or misfiring when i...
    Carbed or EFI?
    Mar 2010
    88 lxi
    lawrenceville, GA
    its efi.check plugs
    88 lxi:
    Quote Originally Posted by Dirt Nasty View Post
    um is 1000 to 2500 rpm considered WOT or what you're stomping it at WOT and the engine seems to be spittering a little till it hums?
    sound like MAP sensor but check for vac leaks cuz those throw off the MAP, but honestley it could be one of a half dozen things. rule out ign, fuel and mechanical all seperatley by inspecting parts and focusing on when exactly this is occuring.
    Apr 2009
    The south end, 206
    EFI. And now it not only does it WOT, but also if I take it easy on the throttle. But Ive noticed it seems like its firing early when i start it, like it doesnt want to fire or it will but die with a not good sounding noise.. Could it have anything to do with my alarms killswitch? or bad cap n rotor?
    EFI the computer can show you a code its under the drivers seat.
    I would disable the alarm just to try it. Change the plugs to regular NGK's gapped to stock on the hood sticker. Inspect the wiring around the cap ,coil etc.
    If you can retime to car to the base timing on the hood sticker as well.
    Could it have anything to do with my bad cap n rotor?
    Um, yes.
    Apr 2009
    The south end, 206
    Thanks for all the feedback.. Guess I just needed new wires.. Go figure.
    Jan 2003
    86 & 87 CRX Si
    Lakewood, CO
    If you have been running it with a miss for a while I would change the oil (unburned gas getting by the rings and into the oil) and change the plugs. It will keep things in good working order.
    Kirk
    Apr 2009
    The south end, 206
    Quote Originally Posted by gtpilot View Post
    Kirk
    No doubt. Changed the plugs, will do the oil.. And thanks.
  1. Engine Misfiring??
    By allhailmj23 in forum EFI Tech
    Last Post: 08-07-2011, 04:06 PM
  2. Misfiring/Low idle
    By Juggalo88Accord in forum 3geez Accords
    Last Post: 02-12-2010, 09:55 PM
  3. misfiring
    By A18A in forum EFI Tech
    Last Post: 01-31-2010, 09:59 AM
  4. 98 Accord Misfiring??!!!???
    By Famous2321 in forum 3geez Accords
    Last Post: 09-26-2005, 11:49 PM
  5. carb flooding
    By powderkey2 in forum Carburetor Tech
    Last Post: 03-17-2005, 03:24 PM
