Page 1 of 5 12345 LastLast
Results 1 to 25 of 118
Thread: Elpuma's 88 hatch
    LX User elpuma's Avatar
    May 2009
    88 Honda Accord lxi
    Grants Pass/Corvallis
    Elpuma's 88 hatch
    These are some pics of the life of my baby girl. I've owned the car since like the end of my junior year in high school. Over the years I've put a lot of love into it.
    Then i painted my car but i don't have any pics of it when i was sanding and stuff. I was inspired by a members paint job.
    I/H/E, B16 mani, delta 272, OBD1....etc
    May 2009
    88 Honda Accord lxi
    Re: Elpuma's 88 hatch
    Here are a few pics of when i went to 3geez meet in Portland.
    I got a flip up touch screen cd/dvd player. Took out the center and stuff to make it fit a lil nicer. I still have my heater working.
    May 2009
    88 Honda Accord lxi
    I got rid of my flip ups and put in some projector headlights.
    Then i made some covers out plexi glass.
    May 2009
    88 Honda Accord lxi
    Then i worked on my wire tuck.
    May 2009
    88 Honda Accord lxi
    I don't feel like re posting all the pics from the other tread i made so imma just put the link
    https://www.3geez.com/forum/showthread.php?t=75872
    When i was on the free way my ball joint failed on me and gave me a scare.
    May 2009
    88 Honda Accord lxi
    Worked on some custom turn signals and tail lights. I used the nite shades on the tail lights.
    May 2009
    88 Honda Accord lxi
    I re located my plate further down and plan to shave the bumper when i do another paint job on it.
    May 2009
    88 Honda Accord lxi
    Got rid of the cable that pops the hood.
    Here's a pic of my interior lights
    Then i put in a civic radiator
    Mar 2008
    Some stuff I like, some isn't as much my tastes, but it's got a lot of work into it and it's coming along really nicely. Keep it up man!
    bridgewater.NS Canada
    So what did you do with the sensor in the rad when you switched to the civic one,Lookin good mann!
    May 2009
    88 Honda Accord lxi
    I had lost my original temp sensor that goes in the radiator. I went to autozone but they pulled out the white one and i said no that not it but they insisted and i was like whatever. I put it into the drain hole of the civic radiator and it fit. I used the same connection i would of used for the other radiator sensor. So far i haven't had any problems using the sensor this way.
    Thanks man,I see you got your black box removed to,so what you runnin beside the map sensor and idle sensor.Do you have your secondary butterflies hooked to direct vacuum.
    LX User NotFast's Avatar
    99' Mercedes E320
    Texass
    x2.
    -Kelley
    Hondas owned: 84 Accord Sedan Lx, 85 Accord Hatch Lx, 87 Accord Sedan Lx, 89 Accord Sedan Lx-i, 96 Integra Coupe Se
    Very nice! So much work!
    May 2009
    88 Honda Accord lxi
    Thanks guys. I appreciate the love.
    My interior started off as too rice and now its just completely gutted. Then i painted the interior black and added black felt to the bottom half all around and put in a black carpet.
    Import racer yea i have the map and idle sensors hooked up. I ran them inside the cabin behind the glove box. As for the secondary butterflies, yes they were hooked up to direct vacuum. But then i got a b16 intake manifold and got rid of them.
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    nice elpuma! hope to get the grey coupe to look like this
    Hey man does it matter which wires go to the idle control module,what color are the wires,want to make sure it's hooked up right since it still idles really low at stop lights and is still idling rough.
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    It sure has come a long way! Keep it up and keep posting your updates.
    1989 Honda Accord LX-I 300K+
    Build Thread
    Washington
    Quote Originally Posted by elpuma View Post
    Great idea. I have been looking into places to weld in an aluminum bung for that sensor. I never thought or using the drain bung. Ill have to see if the threads are the same on the aftermarket radiator I have as well. Just to be clear, you are using the TW sensor same as from the thermostat housing and not the radiator temperature sensor. My radiator currently sits a bit too high for my liking. I need to drop it down about 1/2in more so it clears the top cross bar that used to support the radiator.
    May 2009
    88 Honda Accord lxi
    Import racer i'll get back to you tomorrow on the idle wires.
    Mykwikcoupe yea thats the TW sensor. The radiator temp sensor wouldn't fit in cuz it was too big. I don't remember if the threads matched or not but it ended up working for me.
    Well today I took the engine out because of the knock i started to hear about a month ago. Gonna try to find an ok block to put in. If i can find a whole engine at a good price then i'll buy that. The wet compression test i did put out 185 150 165 155. I was able to get 415,000 miles out of that engine though :-)
    May 2009
    88 Honda Accord lxi
    Finally got her running with a newer block :-). Happy to be going back to OSU with my car.
    Some pics of the bearings out of my block. These are the worst ones out of the all.
    May 2009
    88 Honda Accord lxi
    The polished valve cover that was passed down from rendon to me. This is the first one he polished but tapped wrong so i plugged it and tapped it up higher.
    My catch can i made and painted gloss black to match the engine bay.
    Then I found this filter on the dairy that they didn't need no more. I used this one as a catch can for my PCV system. I took the center parts out of it so it could flow better and got rid of the bottom orange part so i could keep a better eye on the can.
    Looks good man ,keep up the good work.
    May 2009
    88 Honda Accord lxi
    Pics that i took of where the black box goes.
    (the block is upside down)
    What I've concluded is that the oil pan tube that connects on the outside to the black box can be plugged. The hole in the back of the block can be tapped so you can run hose to a catch can. That piece in the first and third pic is pretty much a baffle for the hole in the back of the block.
    May 2009
    88 Honda Accord lxi
    Here's the car that was generous and donated her heart lol
    The heart an a20a1
    Used this neat tool to remove the valves. All you do is hook it up to a compressor and press a button.
    And here it is after pressing it. Makes it so easy to remove them.
    Got everything laid out.
    So basically all i did over the christmas break was get a used block and made it match my old set up. My old block is back at home waiting to get rebuild someday in the future.
  1. R.I.P 85 Hatch
    By 12v in forum 2geez Accords
    Last Post: 03-04-2012, 09:17 PM
  2. New here with an '88 LXi hatch
    By LXiHatch88 in forum Classic Honda Pics & Videos
    Last Post: 03-28-2009, 10:37 PM
  3. Epic Snow Video w/ hot hatch on hatch action.
    Last Post: 12-22-2008, 02:15 AM
  4. my 81 hatch
    By Futu in forum 1geez Accords
    Last Post: 02-26-2007, 03:11 PM
  5. i need the seal/gasket for the hatch on my hatch
    Last Post: 01-02-2007, 01:59 AM
