Page 5 of 49 FirstFirst 12345678915 ... LastLast
Results 101 to 125 of 1219
Thread: The Journey 89 turbo'ed-----89T
  1. #101
    Feb 2004
    Panama City, FL
    Re: before, and after,well in progress
    nice set up
    Pgm-fi conversion 4-16-05
    OBD1 11-25-06
    Turbo 2-26-07
  2. #102
    89T's Avatar
    Apr 2004
    i was hoping to be street tunning next weekend but i am having trouble with the dizzy.
    either i get it figured out or ill have to go with an optical or a magnetic pickup crank trigger.
    un-motivated!
    3GR
  3. #103
    Jun 2001
    Boston MA
    looking good
    S.Q.U.A.D. Engineering
    www.squadengineering.com
  4. #104
    89T's Avatar
    Apr 2004
    thanks
    she 's comming along slowly. The machine shop should be done wih my distributer either today or monday.
    once i get her running she'll get paint.
    un-motivated!
    3GR
  5. #105
    89T's Avatar
    Apr 2004
    aaahhhhaaahahaha!
    i got her running!
    with alittle help from ford....
    heres one for the r&d department.
    I didn't get any pic's of the ford tfi before it was machined..
    un-motivated!
    3GR
  6. #106
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Quote Originally Posted by 89turbo'ed
    aaahhhhaaahahaha!
    i got her running!
    DUDE!!!! you fuking rock!!!!
    get us some more info on what you did there
    -Gio
    My E85 Turbo Build
    5280FEST
  7. #107
    Feb 2004
    Panama City, FL
    Looks great.
    OBD1 11-25-06
    Turbo 2-26-07
  8. #108
    89T's Avatar
    Apr 2004
    Quote Originally Posted by gfrg88
    well there isnt much to say on this mod except for it was easy and the price wasnt too bad.
    i paid $125 for the machine work.
    too tell you the truth i got frustrated with the honda dist..
    the dist. would'nt talk to the commander.
    soo i had a ford dist. sittin around it had plenty of meat on it and it looked like it would be a good match.
    i went to burts machine and told them i needed the base of the ford to mirror the honda 2 days later it was a perfect match.
    the old a20 fired up right off.
    just think of the possibilities.....svo ecu swap. other options such as mass air and tunner software.
    un-motivated!
    3GR
  9. #109
    I'm in love with your engine!
  10. #110
    89T's Avatar
    Apr 2004
    updated pic for you...
    un-motivated!
    3GR
  11. #111
    hotness, seeing your car is making me think of going turbo
  12. #112
    89T's Avatar
    Apr 2004
    heres another one.
    un-motivated!
    3GR
  13. #113
    nice!
  14. #114
    how do you have that lil radiator on there. and are you afraid of the support not being there because you cut that top part of the engine bay where the hood latches to?
  15. #115
    So no DIY info on getting that dis to fit... what car is it from?
    Is the clearance between the cam bearing and the distributor that tight that it doesn't need any screws to hold it in place?
  16. #116
    89T's Avatar
    Apr 2004
    the radiator is mounted on 3 points for now and the support isn't there because these are progressive pic's i have'nt modified and installed it yet.
    by the way its a bolt on peice not a cut out peice.
    a20 there is not alote to tell...this part of the project you need to take it to a machinest.
    all you have to do is tell them to match the honda dist from the base out to the cam key.remove the key and mill the ford shaft to fit the key.
    make sure they have the cap and rotor of both so they can clock the key correctly. pay close attention to the cam key it is slightly off center to only fit one way.
    a few years ago i turbo'ed the first ford tempo with the 2.3 hsc ohv and made about 250 hp to the wheels and is still currntly the worlds fastest :LOL: . i then bought my accord and took alote of The part's i had and built a turbo accord. this dist is from a 86 ford tempo, but you can also use parts from a svo mustang, hsc mustang,thunderbird turbo coupe and a ranger.
    i am not good at write up's so i hope this will do.
    un-motivated!
    3GR
  17. #117
    89T's Avatar
    Apr 2004
    i forgot... bb chevy mount i had to drill a new hole behind chevy hole.
    un-motivated!
    3GR
  18. #118
    A Mile High.
    so does it run???? what ecu are you using?? do you have build a conversion harness???
    -Gio
    My E85 Turbo Build
    5280FEST
  19. #119
    89T's Avatar
    Apr 2004
    she's at the ideling stage of tunning, and I am still putting her back together.
    I am waiting for servion to get back from las vegas to street tune then dyno tune.
    i am using the holley commander 950 standalone and yea i had to make a harness for the altonator and starter wire.
    I am guessing that what you are asking me is if i am using a ford ecu, no.
    but it isn't that hard to pull a ecu and harness from a ford and adapt it to the honda.
    it's just wires and sensors.
    un-motivated!
    3GR
  20. #120
    89T's Avatar
    Apr 2004
    another progress pic....
    un-motivated!
    3GR
  21. #121
    A Mile High.
    dude im loving your car more and more
    what else do you have, as in any internal parts???
    -Gio
    My E85 Turbo Build
    5280FEST
  22. #122
    89T's Avatar
    Apr 2004
    the short block is fully built. JE 10.5:1 pistons eagle H beam rods acl bearings and the rotating assembly is fully ballanced. Everything else is brand new,oil pump,water pump and altonator.
    head work will be the next thing i get done.
    un-motivated!
    3GR
  23. #123
    snoopyloopy's Avatar
    Killa Cali
    wow, 10.5:1 compression on a turbo set-up? that sounds like some good power is going to be produced right there.
  24. #124
    A Mile High.
    holy shit dude, thats fuken awesome!!! so how much boost you planning on running?? what numbers are you looking for on the dyno??
    -Gio
    My E85 Turbo Build
    5280FEST
  25. #125
    89T's Avatar
    Apr 2004
    i should be able to hit 350-400 hp but we'll see...
    as far as boost goes i'll do what it takes to get those #'s
    un-motivated!
    3GR
  1. Turbo 3G role call... Paging turbo'ed guys
    By AccordEpicenter in forum Forced Induction
    Last Post: 06-07-2011, 11:26 AM
  2. My MPG Journey
    By soonerck in forum EFI Tech
    Last Post: 03-18-2011, 08:58 AM
  3. for the turbo guys/wana go turbo/dream of going turbo
    By ZackieDarko in forum Performance
    Last Post: 01-14-2007, 11:22 PM
  4. Replies: 8
    Last Post: 02-11-2004, 05:30 PM
