Results 1 to 25 of 28
Thread: TW Sensor!
    DX User plasmadis's Avatar
    89 SEi Sedan
    San Jose, Cali
    TW Sensor!
    Ah, good evening my fellow 3geezers. Gather around and let me tell you the story of the mysterious TW sensor. Some of you may have already heard of this guy, but for those of you who haven't, this should be valuable information for you.
    Take a look at your EFI engine, and you'll see two sensors above the distributor, under this thing with two vacuum hoses coming out of it. The one on the left, with a green plug, is a temperature sensor. It simply controls when the cooling fan goes on and off, when the car is off. Right next to it, on the right, with a beige plug, is the more important TW sensor. Some places will call it a ECT (engine coolant temperature) sensor, or just a temperature sensor. This guy is likely to give you a lot of grief.
    Having trouble starting? Does it just crank and crank? Does it act like it floods? Does it feel like sometimes your car runs like shit, rough acceleration and idle? Well, first thing to check is your main relay, the solder points could be loose. But that's a whole other story, just Google "main relay site:3geez.com" to read all about it. At first that's what I thought my prob was, so I resoldered the relay, only to find it sorta fixed what was wrong, so after some poking around, I narrowed it down to the TW sensor.
    Well, I was a complete moron and didn't bother to check what code the ECU LED was throwing. Sure enough, it was blinking 6 times, indicating the ECT sensor was bad.
    Now, here's where things get tricky. You'll prob like be like "Well, ima just head down to Kragen and grab one". When I did Google "TW sensor site:3geez.com" I even found ppl here saying they'd just pick up at Kragen. Uh-uh.
    Kragen will sell you this guy:
    http://www.partsamerica.com/ProductD...pe=290&PTSet=A
    You can even ask them and they'll be like "Oh yeah, temperature sensor? Yeah that's the guy." NO! THIS IS WRONG! They'll sell you the one on the LEFT, with the GREEN PLUG. This just controls the fan and won't do shit for your car running like shit. So you'll go back and be like "Uhh, I need the OTHER temperature sensor", and they'll be like "Nah mang, that's the only one I got mang". As far as they know, there is only one temperature sensor they got for our cars. They dunno shit.
    So I called around. Autozone, Pep Boys. They only have that one too. Shit. Sure I can find one online, but it comes from back east, takes a week, and I need one now because I'm tired of my car running like crap and being a bitch to start.
    BTW, the TW sensor does a great deal, I've found. It's what tells the ECU how much gas to give the engine, based on its temperature. If the engine is cold, it'll give it more gas, and if it's hot, vice versa. This is especially important when starting. With a bad TW sensor, the ECU thinks the engine is always cold, so it'll give it too much gas, you'll sit there cranking and cranking, and the engine floods. This happened to me once, leaving me stranded in a grocery store parking lot (BTW, this is also a symptom of a bad main relay, which I also then fixed). So, a temporary solution, which I found here on the site, is the "paperclip method", haha. Just stick a cut paperclip in the TW sensor plug. This gives a closed circuit to the ECU from the sensor plug, making it think the engine is always warm, so it won't give it too much gas. This saves you from flooding it, however, it makes starting a bitch, as you gotta give it just the right amount of gas as you crank it, then rev it a little before it'll idle properly. If you don't, then it dies, since the ECU doesn't really know what to do. Man, it was like I had a carbed 3gee again! Those damn carbs! :p
    Anyway, I just decided to hit up the dealer. Capitol Honda here in San Jo knew exactly what I was talking about, pulled up the Honda part number, but then they didn't have it in stock. No! But wait, he was kind enough to tell me the Honda on Stevens Creek had it. What a guy!
    And here it is, the guy that saved me from these past 2 weeks of grief:
    Ouch! 40 bucks!
    Here are the old sensors:
    The bigger one is the sensors that controls the fan, the green plugged one, the wrong one Kragen sold me. It was working fine, but I went ahead and put in the new one anyway.
    And here are my shiny new sensors installed:
    Yay!
    And thus concludes my adventures with these damn sensors. The car runs like a champ now, starts like it's brand new, just cranks over about three times (rrr, rrr, rrr), and vrooooom it's goin. Also acceleration and idling feel a lot smoother. As someone on here said, "it feels like a new car".
    Change your TW sensor, you'll be glad you did!
    plasmadis
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: TW Sensor!
    Good info.
    CARDONE SUCKS.
    Re: TW Sensor!
    dude....i need to change those as well as the temperature gauge in the rad....my fans dont turn on at all...so i had to wire them....they run all the time now. so both sensors were 41 bucks? i get mechanic discount at honda.....so hope it gets the job done.
    89 SEi Sedan
    San Jose, Cali
    Re: TW Sensor!
    Just the TW sensor cost me 41 bucks from the Honda dealer. :p The other sensor is the one for the fans, the one I got from Kragen, for 23 bucks.
    If you're having a prob with the fans turning on, it might also be the fan relay, which is in the engine compartment fuse box.
    plasmadis
    Re: TW Sensor!
    Lil idea i always had was put a pot between the output of that sensor and the ECU and you got crude fuel control.
    LXi User coope's Avatar
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: TW Sensor!
    man my light was cumming on and it is hard to start sometimes it's like it was out of gas or sumthing i had replaced fuel filters and such thanx will get rite on that thank God for u !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    redaztec's Avatar
    89 Accord LX-i 5spd
    USA
    Re: TW Sensor!
    If I'm not mistaken, it appears that Autozone sells the TW sensor: part number SU4006.
    Thanks for posting this - you probably saved me from buying the wrong one (I think my TW sensor needs replacing too).
    carotman's Avatar
    Montreal South Shore
    Re: TW Sensor!
    Some 3geez don't have that green sensor there. It's there if you have the fan delay control module.
    Notice how the thermostat housing has a blank hole where the fan sensor is supposed to be.
    I need these parts!
    SE-i Sedan 5 spd
    Re: TW Sensor!
    I started having trouble with the TW sensor about 2 weeks before it got so bad that I was afraid to turn the engine off away from home. I ordered it from the Honda dealer and ended up changing it out in the dealer's parking lot. I'd advise people to just get a new one now, because sooner or later it's gonna go. Same for the main relay, although it's a PITA to install.
    86Accord LXI
    In the woods
    Re: TW Sensor!
    I don't live within 200 miles of a dealer and the only parts store that had a clue and could get one was napa.They knew what i was looking for and it
    is just like the one in the pic above.Mark
    Mar 2010
    1989 Honda Accord LXi Coupe, 1995 Dodge Ram 1500
    Huntington Beach, CA
    Re: TW Sensor!
    Can someone confirm this?
    Is this part that Rockauto sells for $15 the infamous TW sensor that may be causing my erratic idle and non-starting issues?
    Quote Originally Posted by redaztec View Post
    SE-i Sedan 5 spd
    Re: TW Sensor!
    Ya know, I know some of you guys make it a point of principle never to go near the Honda dealer. But really, a quick stop there, even if they had to order it, would get you one in a day or two.
    Amusing story plasmadis.
    LX User stephensimmons's Avatar
    Jan 2010
    89 Honda Accord LX-I
    summerville,south carolina
    Re: TW Sensor!
    Quote Originally Posted by w261w261 View Post
    Some of them rather spend $20 on something that will work then to spend $40 on something that will solve all their problems.
    Jan 2010
    Re: TW Sensor!
    Quote Originally Posted by Harrison_Bergeron View Post
    Ill almost bet you my next pay check that it isnt.
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Re: TW Sensor!
    TW sensor stands for Thermal Water or Temperature water sensor, so it is called ECT sensor ( engine coolant temperature sensor) when you ask or look up parts on sites other than dealer. Honda just calls it TW sensor. As for idle it could be a bad IACV ( Idle Air Control Valve). 88-89 have this valve. I had a bad one, was idling a small bit bad on start up, tried cleaning it first but that didn't get it, so I bought a new one and idles like new. These will not always throw a code.
    My '66' GT I built. My first Hot Rod magazine Cover "Summer 85". I've had it for 32 years, since I was 18. It's a trailer queen. 289 Hi-po, t-10 Toploader 4speed, 9 inch rearend.
    Apr 2009
    Orange County Cal.
    Re: TW Sensor!
    Here is a NAPA parts list I use to get NAPA part numbers.
    http://www.dmauto.com/web/dmauto/catalog/
    Mar 2010
    Re: TW Sensor!
    I forgot the link:
    http://www.rockauto.com/catalog/moreinfo.php?pk=945853
    I have compiled a list of all the things that may cause my issues based on 3geez info:
    IACV
    TW Sensor
    Vacuum Advance
    Main Relay (my starting issues seem more like the ones caused by the TW flooding the engine on a cold start)
    Transmission shift sensor(was in the manual, my idle drops almost to stalling when put in gear)
    I think I may have multiple idle/starting issues, but the TW seems like a likely culprit from what I've read. I plan to clean the IACV tomorrow.
    Apr 2009
    Orange County Cal.
    Re: TW Sensor!
    I forgot the link:
    Yes on both, but cleaning the IACV does not always work on these vehicles, you may want a new one later.
    Re: TW Sensor!
    That is the TW Sensor, but you really should buy the Beck Arnley part for $21 and not some off-brand thing. If it's failing, it will usually start throwing codes so yours is probably good enough not to cause huge problems. Why don't you describe your symptoms in a new thread?
    DX User rohwer's Avatar
    Jan 2011
    1989 Accord LXi
    SLC, UT, USA
    Re: TW Sensor!
    This thread appears to sum up the issues that I am having as well. I already rebuilt, then replaced the IACV. New spark plugs and wires. Things worked better for a few weeks, but now it takes 20 min to start the car. I just ordered a new TW sensor. I hope it takes care of the problem. Thank for the great info.
    Dec 2013
    1989 Honda Accord Lxi 2 Door Coupe; 1989 Prelude 2.0si
    Seattle, Wa
    89 Accord fans do not turn on even with A/C running
    Ok, it always seems like one thing after another with this 89 Lxi. Was driving to work this AM, and when I got close to work I noticed the Temp gauge was pegged. Ive done the, turn on A/C on to verify Driver side fan works, which it did when I first tested it when I got to work. Now A/C is blowing warm, when it was cold as all get out Yesterday. I jump the fan relay under the hood, and the passenger, (cooling) fan does engage. My last Accord, an 86 did the same thing @ about the same mileage. I hooked up a switch to the fan realy to turn the cooling fan on when needed.
    I pulled the plug to the green connector on the thermostat assembly, & noticed oxidation inside the plug. I cleaned it out as best I could. Maybe need new plug. However, when I jumped the plug wire side to make a voltage connection, nothing happened, no fans. @ least I can jump the fan relay and get me home from work, but any ideas @ this point? Why would a fan issue all of a sudden cause my A/C to blow hot overnight? Do I need a Fan switch or what?
    Thank you for any ideas on where to troubleshoot this.
    carotman's Avatar
    Re: TW Sensor!
    Do you have voltage at the plug?
    I need these parts!
    epic1400cs's Avatar
    Jun 2004
    1989 CA5 Aerodeck EXi 2.0 A20A4
    London, UK
    Re: TW Sensor!
    Thank you very much for this informative thread. My aerodeck has been suffering from sporadic non starting issue as well as changing idling speed depending on the weather/temp of the day. I have changed the main relay, deep cleaned TB, swapping fast idle valve etc but no improvement and finally found this thread! The result is fantastic and my car is running well again!
    For UK and European owners, Honda's TW sensor is very expensive but I didn't want to use unknown third party parts so I opted for Rover genuine parts. Back in the day Austin Rover was working with Honda and not many but some parts are the same as our car and quite often these are made in Japan.
    XHM344 OE SENSOR-TEMPERATURE
    It was about £30 incl. shipping - not cheap but considerably cheaper than Honda price. The one I have received was made in China but its shape etc are exactly the same as Honda OE and it is working wonderfully.
    carotman's Avatar
    Re: TW Sensor!
    Good to know, I sometimes had a hard time starting the car when it's hot too. Time to check that sensor.
    I need these parts!
    Re: TW Sensor!
    Check the connector too. I'm sure it's mentioned in this thread, but it's super common for those wires to break with how tight the bend is on them at the connector.
  1. cylinder position sensor and TDC sensor
    By newaccorddriver in forum EFI Tech
    Last Post: 04-21-2011, 10:02 PM
  2. Coolant temp sensor tw sensor
    By Bluntman in forum 3geez Accords
    Last Post: 07-06-2009, 06:12 PM
  3. cylinder position sensor and TDC sensor
    By newaccorddriver in forum Classic Honda Community Chat
    Last Post: 11-28-2006, 10:29 PM
  4. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
  5. Quick, Which o2 sensor is the primary sensor
    By 89accordlxi in forum 3geez Accords
    Last Post: 11-03-2002, 07:23 PM
