ok, just to add to the confusion:
the '89 actually had
THREE different front mounts. the '89 lx-i/se-i had its own special
mount, the 50810-SEO-J31. it is not liquid-filled.
so,
86-88:
5MT and 4AT (all): 50810-SEO-932 (solid?)
89:
5MT (DX, LX): 50810-SEO-932
5MT (LX-i/SE-i): 50810-SEO-J31 (solid)
4AT (all): 50810-SEO-A02 (liquid-filled)
i don't know about the 932, but after comparing the A02 with the J31, it appears that the auto
mount is taller. by at least a ¼". at first i thought this might be because the auto
mount compresses more when under load, but that does not appear to be the case. the 5-speed
mount is only slightly stiffer, if at all, than the auto
mount. which leads me to believe that the auto and manual transmissions may have a different mounting bracket for the front engine
mount.
on majestic's site, there is a single diagram that appears for engine mounts regardless of which trim level or year you type in:
as for the
mount brackets, this is where it starts getting a bit confusing. there are apparently three different mounting brackets, but on majestic's site they are listed in a very odd way that doesn't make sense. i think i'll have to take a trip to the junkyard to figure this one out.
