Results 1 to 24 of 24
Thread: Sensors and their basic failure symptoms
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    I know a lot of us on here understand the sensors on vehicles, but some of the people on here are just learning, so I thought this may help them understand the functions of certain sensors and the failure symptoms. Not all these sensors are on the 3rd gen, but most are.
    All vehicles from 1980 on (except for some big trucks) have some sort of computerized engine controls. The fuel/air mixture and often the ignition timing are electronically adjusted according to engine load, speed, temperature, even the altitude above sea level!
    The newer cars also use either the engine control computer or a separate computer to shift the transmission.
    All manufacturers call their computer components by different names, but all the systems are similar in function. Here is a list of the most common sensors and what they do. Most all sensors provide a variable resistance to the computer to let it know what's happening. 5 volts are fed to the sensor, and it returns 0 to 5 volts back to the computer. Although later systems can do without certain sensors and still run, many systems will run poorly or not at all because of one defective sensor.
    When a sensor voltage falls out of specifications, the computer will illuminate a "CHECK ENGINE, SERVICE ENGINE SOON, OR MAINTENANCE REQUIRED" light on the dash. The new technical name for this light is the "MIL" light. This stands for Malfunction Indicator Light. If this light is on in you car, it means the computer has received a bad reading from one of the sensors.
    Most computers have a set of trouble codes which can be recalled even after the engine is turned off. These codes tell which sensor gave an "out of specs" reading. If the light comes on then goes off, the problem is intermittent. A code has been stored, however, (on all domestic, most newer imports) , and this code can be retrieved to help find out what sensor went out of specs.
    If the light is on all the time, the sensor is out of range all the time. Your car may go into a "limp home mode" where it assumes a set of values for the bad sensor(s). The car will get bad gas mileage when in limp home mode: it can run really badly!
    MAP SENSOR: This stands for manifold Absolute Pressure Sensor. It's nothing but an electronic vacuum gage. As the manifold vacuum changes, the MAP sensor supplies a variable voltage to the computer.
    FAILURE SYMPTOMS: Poor running, stalling, light on dash
    NOTE: A MAP sensor can be inaccurate, sending an incorrect voltage to the computer. If this voltage is still within the range of voltage the computer expects, a light or trouble code for the MAP sensor may not be set. Fords are particularly susceptible to this. problem. Thus, if the MAP is old, it might be a good maintenance item.
    TEMPERATURE SENSOR: Often a car will have several of these. All of them have a coolant/engine block temperature sensor. Some also have a manifold temp sensor and an intake air temperature sensor.
    FAILURE SYMPTOMS: Rich or lean mixture, black smoke (rich), light on dash
    THROTTLE POSITION SENSOR: This lets the computer know how far you press the accelerator pedal down. It often has a wide open throttle and a closed throttle switch either as part of it or as separate components.
    FAILURE SYMPTOMS: Hesitation on quick acceleration (passing, "floorboarding it") , sometimes bad idle. May not illuminate light or set codes.
    MASS AIRFLOW SENSOR: The latest thing: this actually measures how much air enters the engine and adjusts the fuel/air mixture accordingly.
    FAILURE SYMPTOMS: Poor running, stalling: all conditions. May not illuminate light or set codes.
    OXYGEN SENSOR: This measures the exhaust oxygen content. The computer fine tunes the mixture using data from this sensor.
    FAILURE SYMPTOMS: Poor fuel economy, driveability, light on dash.
    THE HEGO SENSOR (Heated Oxygen Sensor): First seen on Fords, this is just an Oxygen sensor, except it's HEATED! Heated Exhaust Gas Oxygen sensor. It is electrically heated so it works immediately on engine startup: the other type must be heated by the exhaust before it starts to work. Computers using these place a lot more emphasis on the data from the Oxygen sensor, and use this data sooner while the engine is still cold.
    CRANKSHAFT/DISTRIBUTOR/CAMSHAFT POSITION SENSOR: Used on all engines with computerized timing advance, this tells the computer which cylinder should be firing. Some engines use a sensor on the front pulley of the engine (Harmonic balancer or vibration dampener), another sensor in the engine block on a special toothed wheel on the crankshaft inside the engine block, and a third sensor on the camshaft gear. Earlier systems have a pickup inside the distributor as the only input as to crank position.
    FAILURE SYMPTOMS: No start, hesitation, misfire
    BAROMETRIC PRESSURE SENSOR: This adjusts the mixture according to altitude: the same settings won't work both in Denver and Death Valley!
    FAILURE SYMPTOMS: Poor fuel economy, light on dash
    In addition, the computer often monitors things like vehicle speed, brake pedal on or off, power steering pressure, A/C on or off, and transmission shifter position (tells it what gear you're in).
    FAILURE SYMPTOMS: Poor fuel economy, light on dash, stalling while parking or at traffic lights
    All vehicles do not have all of these sensors.
    THE CRITICAL SENSORS:
    All sensors must function properly to obtain maximum fuel economy. However, only a few of them are crucial for proper engine operation. For instance, on many vehicles there's a vehicle speed sensor. If the speedometer cable breaks, the "CHECK ENGINE" light will come on, but the car will appear to run normally. (A vehicle speed sensor CAN make your transmission not shift on a computer controlled transmission!) On the other hand, a bad MAP sensor can make some cars (especially Fords) barely run!
    For most cars the "essential" or "major" sensors are: MAP sensor, Mass Airflow Sensor (if so equipped), Engine Block Temperature Sensor, and the Crankshaft/Distributor Position Sensor. These sensors can make an engine barely run or not run at all. The other sensors make very fine adjustments to the fuel/air mix and timing and will not cause a gross poor running condition.
    This is important, because often a "major" sensor will cause a "minor" sensor to read out of specs. If the car barely runs, or doesn't run at all, suspect one of these "major" sensors (and other non-computer stuff, like wiring, coil, or fuel supply) before trying to trace down a code generated by a "minor" sensor.
    FOR EXAMPLE : BE CAREFUL WITH COMPUTER CODES: THEY CAN MISLEAD YOU !
    Your car smokes black, smells like gas, and barely runs. The computer gives a "rich oxygen sensor" trouble code. The Oxygen sensor is replaced. The car still smokes black, still has a "rich oxygen sensor" trouble code. The codes said the Oxygen Sensor reads rich.
    This just confirms what any good mechanic could tell by smelling the exhaust: it's running rich!!
    The car really needs a temperature, MAP, or Mass Airflow sensor , or possibly a carburetor rebuild or fuel injection service.I've seen Chryslers with bad Throttle Body Injectors smoke, give rich Oxy sensor readings at idle, but setting no other trouble codes.
    LIMP HOME MODE: When the computer decides enough sensor inputs are out of proper range, it will go to a "limp home mode". This mode has effects from almost unnoticeable to fairly radical, depending on what car you have. The mild case is a MIL light and bad gas mileage. Some cars (with computer shifted transmissions) will stay in second gear when in limp home mode!
    In limp home mode, the computer uses assumed values to control fuel and spark rather than measured (and constantly adjusted) values. This results in poor fuel economy and bad driveability.
    OBD 1 AND OBD 2 (OBD I AND OBD II)
    In an effort to standardize computer control systems on vehicles, the government mandated manufacturers put a standardized data collection system on newer vehicles. This system is called OBD (On Board Data) one and two. The cars may have other proprietary data interfaces, but they MUST have the OBD interface if they are sold in the U.S.
    The new interfaces have literally hundreds of trouble codes which can help a lot in diagnosing your vehicle. code scanners to read these codes have gotten much cheaper recently. Several parts stores will read these codes for free.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: Sensors and there basic failure symptoms
    Great info! I'd personally say this is good info even for someone who is semi-experienced. Helps understand how the ECU system works.
    '89 SE-i Coupe
    Awaiting Garage
    Millington, TN
    Dude, too cool.
    This should go into the Technical as a sticky.
    Just awesome info.
    Phil
    Good stuff Bluntman!
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    good info bluntman
    would like to add if i could that mass air flow(MAF) sensors have been around in one form or another since the 70s
    ones that old will most likely be of the trap door type which is pretty much a potentiometer attached to a flap which is spring loaded and is displaced by the airflow and the value of the pot changes and thats what the ecu reads.
    the other are hot wire, what nissan use and ultra sonic( karmann vortex ) found on mitsi's. toyota dont matter coz they are boring
    they all suck in comparison to map/tps which honda use coz they offer restriction to airflow, albeit a very small resistance, its a restriction none the less.
    but thats my opinion coz honda's are way better than the rest.
    Apr 2009
    Orange County Cal.
    Dude, too cool.
    Just awesome info.
    I think it would be great, so that people can understand what the purpose of each sensor is, and how the ECU operates. It may come in handy down the road.
    Apr 2009
    Orange County Cal.
    Re: Sensors and their basic failure symptoms
    Bump so it does not get lost, and it may help people.
    SE-i Sedan 5 spd
    Do you have to have a separate reading tool to get info from OBD I cars? Is the interface different?
    Yeah, thanks bluntman. I vote for that to be stickied.
    LX User gtmst3's Avatar
    Jul 2008
    1986 honda accord LX
    Waterbury
    i diddnt read through the wole thing yet but actually the sensors return between .5 and 4.5 volts any lower or higher it trips the mil
    hondas dont have nearly as much trouble as domestics with sensor issues.
    DX User seancmadison's Avatar
    Jan 2013
    1988 honda accord dx 30,000 mile 1.8 replacement
    willits ca
    1988 3g dx carb auto I have been having a issue wile in drive wondering if any one has had a similar issue the car will idle great then randomly fluctuate from lets call it 1×1000 to 1.2×1000 wile driving or stopped. Them today after getting gas it died. Crank just fine but acting like no spark. After a hour and a roadside assistance call later it started. Ran all day then on the way home it did its stupid rev fluctuations again. Its dangerous in traffic cause when it fluctuates it wants to pull me forward and im in stand still traffic and it wants to go. It never goes over that .2 increase but im sure its a sensor cause I have been driving it almost non stop.
    The bouncing idle is almost always caused by one of two things: 1.) low coolant 2.) vacuum leak
    Jan 2013
    willits ca
    Ok I had low coolent and fixed that but its only bouncing in drive and is like I'm stomping on the gas quickly and non stop
    Not sure if you did, but you'll need to bleed the cooling system if the coolant was low. Just topping it off will leave bubbles in the system.
    Having said that, the typical bouncing idle is a gentle rev up and down between two specific RPM points. Yours sounds like it might be different from that. You might start by removing the air filter box and viewing the operation of the carb while it's doing this. I'll confess that I don't have any ideas.
    Jan 2013
    willits ca
    I did blead the system. It had no change when I filled the water and I checked all vacuum lines for leaks. Its almost a miss and my first post said it was raising rpm slightly but further diagnosis it is dropping then catching to normal .
    Jan 2013
    willits ca
    Now it has stopped for now. Wondering if I could have wiggled something loose that could cause this symptom?
    Jan 2013
    willits ca
    It only has the problem wile in drive and I would need someone in the car pushing firmly on the breaks to see what the carb is doing wile the symptom is present
    I'd be looking at electrical stuff like wires, distributor and ICM. The other thing would be to check the function of all the electric solenoids and vacuum actuators on the carb.
    Jan 2013
    willits ca
    I have checked and checked again the vacuum lines found a small seep from the trans cooler line fixed that re topped off my water then took off my cap as it has about 30,000 on it. It was very corroded I cleaned it but still the problem persists. The carb is brand new and I really dont want that to be the problem but besides the coil and module on the dizzy after testing that it would have to be the carb
    one I wanted to add, almost no one knows this, but the carb ECU uses a temp sensor on the back of the block, just like a FI ECU, it's one of the parameters that it uses to set mixture in the intake manifold. It's hard to even find info on it, unless you know it's there and you find it on the diagram for the ECU
    Jan 2013
    willits ca
    Ok got it fixed with trial and error. It was the distributor cap and rotor or the oil in the distributor I sprayed out with automotive electronic contact spray cause I didnt want to melt any plastic. I also found or wiggled free two spark plug wire connectors and I re attached those and it works no rpm drop.
    Quote Originally Posted by seancmadison View Post
    Time for a new distributor.
    Jan 2016
    1987 Honda Accord LX KA4AT
    Distributor seal kits sell for 4 bucks plus shipping on Rock Auto. I would do that before buying a new distributor. Also, if the carb is new, re torque your carb mount bolts. Vibration can back these out, which opens up a vac leak at the lower mount gasket. Just some extra info that might help someone out. Good luck, everybody!
    May 2009
    Excelente Información, para quienes les motiva meter las manos en el vehículo. En mi País, los dealer ya no entregan servicios a a vehículos sobre 30 años, y los Talleres no tienen toda la experiencia para resolver tus problemas. Pero si además de entregarles el vehículo para que te lo reparen y les adjuntas esta Info, de seguro encontrarán más rápido y certero, la solución. Gracias.
  1. what are symptoms of a bad distributor
    Last Post: 02-28-2012, 08:05 PM
  2. 32/36 basic jetting
    By 2old_honda in forum Carburetor Tech
    Last Post: 10-23-2008, 03:21 AM
  3. Symptoms of a bad trans?
    By slowsixtyseven in forum 3geez Accords
    Last Post: 04-07-2005, 01:27 PM
  4. CV joint going bad... what symptoms did you have?
    By dysiu in forum 3geez Accords
    Last Post: 05-14-2004, 09:49 PM
  5. basic amp and sub question
    By danronian in forum Interior & Exterior Care
    Last Post: 08-02-2003, 07:53 PM
