Results 1 to 13 of 13
Thread: Horrible noise. :( *video
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    I'm not certain cause it sounds like a valve tap, but it also sounds like its coming from my pump. But it also sounds like I hear a taping noise coming from my oil pan, like a "clink, clink clink" noise.
    I don't have alot of time left I leave tomorrow, most likely by plane now but I would like to figure out what the problem is. I've come to far now to give up on the car.
    Also here is a video. :3 I know its the only way to figure it out.
    YK86's Avatar
    Oct 2000
    BC, Canada
    Re: Horrible noise. :( *video
    I'd hate to say it but it sounds to me like rod knock. But the sound I hear is more like a thump/tap than a light clink.
    www.b20accord.com
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    I really hope not.
    This car has been a total nightmare. >.> and yet for some reason I don't want to give up. How much do you all think it will cost to machine it, if I do it I might as well go all the way and overbore do new pistons, rods, cranks, seals, everything. I will have the car with me in about a month.
    and then I will put money aside for the next 2 months and just a whole rebuild.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    get a magnetic oil drain plug. thats the quick and dirty way to see if you spun a rod bearing. if its a repetitive knock/tap its highly likely you're bottom end is going/gone
    Nothin' 2 Old Racing
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    Quote Originally Posted by NXRacer View Post
    Well truth be told it wouldn't surprise me if it was something else.
    We just replaced the rod bearings, However I'm certain the car needed it long before I even had the issue.
    I guess I'll just do a full rebuild when I get the car in cali. to much money already spent and way to much time to just give up on her.
    Pretty sure thats a rod. Sounded just like my blown up 89.
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    :3 got a estimate of a good rebuild price range?
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    sucks but did it sound like that before putting new rod bearings?
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    Quote Originally Posted by ShyBoyCA6 View Post
    No...Before I put the bearings in the car couldn't even get above 1500RPM, and it wouldn't go above 20mph. and the noise was different, like you couldn't hear it until the engine warmed up.
    I was able to take it to the exhaust shop and a few other places and had no trouble getting up to speed and no issues with the RPMs.
    Maybe my crank got screwed up when the old bearing went.
    Oct 2009
    Quote Originally Posted by Nio View Post
    hmm that sucks Nio i guess the rebuild will have to do then.
    Did you just drop the pan and replace the bearings? I would call that a long shot at best. I know some folks do that, but if you have problems in the bottom end, it's time to pull the engine and do a proper rebuild. I'm really not a fan of half-measures unless you are just trying to squeeze another few miles out of the car before junking it. You may have fixed the most obvious problem, but other problems will be waiting in the wings. Each time you fix the worst problem, you'll have to pull apart and redo what you did the last time. It's not cost effective at all. You may have fixed the rod bearings and ended up with piston slap.
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    rod knock x3
    Same noise everytime i started up the 89. Sounds exactly like it.
    yeah that is not a good noise...you might to do a bottom end rebuild
  1. Horrible squeaking noise while driving
    By A20A1_88Accord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-04-2009, 09:35 AM
  2. Horrible gas mileage...
    By Acid X in forum Carburetor Tech
    Last Post: 01-16-2006, 01:52 PM
  3. horrible smell
    By 2drSE-i in forum 3geez Accords
    Last Post: 12-06-2005, 02:04 PM
  4. what a horrible day...
    By AD9SloAccrd in forum Interior & Exterior Care
    Last Post: 05-05-2004, 06:40 PM
  5. This is just horrible
    By shaodome in forum Classic Honda Pics & Videos
    Last Post: 06-28-2002, 08:20 PM
