Results 1 to 21 of 21
Thread: Exhaust size?
    LX User stephensimmons's Avatar
    Jan 2010
    89 Honda Accord LX-I
    summerville,south carolina
    Exhaust size?
    What size exhaust tubing are you running? And do you have clearance problems?
    2011 Is going to be my year to do it or give it up!
    Re: Exhaust size?
    Quote Originally Posted by stephensimmons View Post
    https://www.3geez.com/forum/showthread.php?t=74719
    https://www.3geez.com/forum/showthread.php?t=74744
    DX User Clint's Avatar
    Sep 2011
    1989 Honda Accord DX
    Far West Kentucky
    Re: Exhaust size?
    I went through both threads - found a reference to 2" - My buddy who does custom pipes says 2" should be plenty for a 2L motor that is not too heavily modified.
    _________________
    Clint
    Far West Kentucky
    '89 DX
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    Re: Exhaust size?
    I'm running 2.25 inch mandrel bent piping, and it's too big for a stock Accord. It took a cam, and bigger carbs before the low end power loss went away.
    Re: Exhaust size?
    2.25
    Re: Exhaust size?
    Quote Originally Posted by Clint View Post
    Remember if you have mandrel bends you dont have the bend restrictions,there are guys running much more horsepower then most of us do, i went 2 inch mandrel bends because im going to be running two big carbs,cam,ignition,headwork,full length headers etc
    LX User elpuma's Avatar
    May 2009
    88 Honda Accord lxi
    Grants Pass/Corvallis
    Re: Exhaust size?
    2.25
    I/H/E, B16 mani, delta 272, OBD1....etc
    Re: Exhaust size?
    Quote Originally Posted by elpuma View Post
    2.25
    there are guys running 500 horsepower with 2.5 inch pipes 2 will be fine for most of these cars,f you go too big you loose scavenging ability
    May 2009
    88 Honda Accord lxi
    Re: Exhaust size?
    mines not mandrel bent though
    Re: Exhaust size?
    then just go 2 1/4 , if you are running a stock engine or close to it, then 2 even with regular bends is probably fine
    Jan 2010
    Re: Exhaust size?
    Me not going to be near stock. Going to push the 2.0 to the limit then start all over again with better stuff. But in the mean while im going to have fun with it.
    89T's Avatar
    Apr 2004
    Re: Exhaust size?
    3"
    Re: Exhaust size?
    I have 2" stainless mani bent with one muffler at the rear on stock engine with cai and advanced timing. Manual.
    Re: Exhaust size?
    I have couple of setups for my various cars, the racing lude has 2.5" mandrel bent with 2" down pipes and 2.5" collector very unrestrictive and gave reasonable power gains over the old system which was 2" but I think 2.25" would have been very similar I don't seem to have lost anything low down just gained power nicely overall and bit more top end power.
    On my mint lude I didn't want anything too loud as it's a nice Sunday sunny day driver and the engine is only little bit tweaked as apposed to full on racing spec like the other one so just has, stock tweaked carbs, and modified intake box with a 2" mandrel bent system with twin exit rear silencer, middle sports silencer, and 1.75" down pipes into 2" collector. This setup made 115bhp and 127.5lbft from A18 engine fitted a 272 degree cam and feels like a very healthy 130-135bhp and pulls very nicely to 7500rpm.
    Jan 2010
    Re: Exhaust size?
    3"
    Clearance issues?
    Re: Exhaust size?
    3" is a waste unless your going full blown turbo or mental N/A build on a H23 vtec hybrid I also suspect it's crush bent as well, you'll be better off with a nice mandrel bent 2.25" lighter and high flowing if you really are trying to get 200bhp plus out of the car then custome header with 1.5" primaries, 2" downpipes and 2.5" mandrel bent system all day long but you'll be needing to talk to me about heads, valves and some pretty trick induction system to make that kind of power.
    89T's Avatar
    Apr 2004
    Re: Exhaust size?
    No crush bends, lol.. With a precision billet 6262. I am not looking for what? the 4**hp slip that has been done. I am looking for way more in a steet car.
    There are no fitment issues with the 3" and vibrant muffler.
    Jan 2010
    Re: Exhaust size?
    Quote Originally Posted by rjudgey View Post
    Trying to get over 200hp?!? If thats all I would get I wouldnt even be spendind my money or taking this long to get the car going. And as for the head it's being worked on as we speak of this and a few other things to.
    Re: Exhaust size?
    he knows what he's talking about, he can give you some good advice and knows quite a few tricks
    Jan 2010
    Re: Exhaust size?
    I never said he didnt. I dont even know him to say he dont.
    Re: Exhaust size?
    If you give us a more accurate picture off what you are trying to build would help a lot more.
    Can you detail what headwork you are having done other than it's in the head shop now?
    Are you going with a full blown turbo setup or Naturally aspirated setup?
    If it's a Naturally aspirated setup you need different type of headwork versus turbo setup.
    I have the most worked on heads and have been doing headwork on these for the last 10 years I also know quite a bit about building the blocks to some pretty tight specs. I have built quite a few 200bhp ET/A20 engines in the last 5years and before that ones with 170-180bhp.
    You really have to know what you are doing with these engines to get more than 180bhp Naturally aspirated if you are going turbo then 3-400bhp is easy but building it so it doesn't melt a pistons or burn a valve is another story!
    If your going N/A build then 2.5" mandrel bent system is perfect, but you'll have to have a custom header made 1.5" primary and 2" secondaries, 2.5" collector.
    If your going Turbo 3" downpipe and system mandrel bent will be more than fine but make sure you find a mandrel bender not crush bender.
  1. 82 EK1 Stock exhaust size ?
    By ekoms in forum 2geez Accords
    Last Post: 07-14-2009, 08:55 AM
  2. Stock exhaust size?
    By Nafs Asdf in forum Classic Honda Community Chat
    Last Post: 02-28-2008, 11:31 PM
  3. exhaust manifold nut size
    By 86-accord-lxi in forum Classic Honda Community Chat
    Last Post: 11-14-2005, 04:45 PM
  4. Exhaust Tip Size
    By SteveDX89 in forum Performance
    Last Post: 07-30-2003, 01:57 AM
  5. max size for catback exhaust?
    By 89accordboi in forum 3geez Accords
    Last Post: 12-19-2002, 02:10 PM
