Results 1 to 10 of 10
Thread: Another Weber install [pics inside] + questions.
    Sep 2009
    87 Accord
    San Antonio, TX
    I finally got tired of messing with the stock carb.
    This is what came in the package.
    Will add more pics soon.
    Stock engine bay:
    Starting to rip stuff out!
    1987 Nineteen Eighty-Seven Honda Accord DX Hatchback
    Sep 2009
    87 Accord
    San Antonio, TX
    Re: Another Weber install [pics inside] + questions.
    No more carb + other useless stuff.
    Scrapping off a gasket. It was very difficult to remove.
    a little bit a degreaser cleaned up that manifold.
    Aug 2007
    1987 Accord Carbed Auto Stock
    Hey, it is looking good so far. Keep updating and posting pictures please.
    Sep 2009
    87 Accord
    San Antonio, TX
    Found this bit in my dad's tools for the coolant port.
    Came out good, huh?
    Can I get rid of these two canisters?
    put in a new fuel line for the new fuel filter and line from the dizzy.
    another angle.
    This was hard to remove. I actually tightened it even further!
    This did the trick.
    Sep 2009
    87 Accord
    San Antonio, TX
    I think my starter may be bad. I started it up and eventually the cranking got slower and slower. I checked the battery voltage and it seems good.
    DX User 2ndGenPreludeSi's Avatar
    Jul 2011
    1986 Honda Prelude 2.0Si
    Bend Ore.
    Did you ever figure this out? 11.4V means that battery is dead bro.
    12.6-100%
    12.4-75%
    11.4-toast
    hey yeah we never did see the weber actually on the car yet! A great pictorial thread thus far...
    Sep 2009
    87 Accord
    San Antonio, TX
    I will get more pics up soon!
    Quote Originally Posted by 2ndGenPreludeSi View Post
    12.6-100%
    12.4-75%
    11.4-toast
    I'm having some systematic problems with the battery. Like it will sit for a couple of days and then it needs to get jumped. I think I may have had to get it recharged too many times and degraded the battery. so I need a new battery. Thanks for the info!
    What are you plugging the AS port on the exhaust manifold with?
    Wow that is a huge line for the vacuum port on the dizzy. You didn't have any hard lines or adapters left over from the tear down?
    I see you're using the same fuel filter I had on my setup.
    I wish I had bought my webers new, instead I got two from a duel setup for $75 each on ebay.
    Quote Originally Posted by STITCHES View Post
    yea 11.4 is discharged. Recharge it and try again.
    make sure your headlight retract motors are working. If they do not reach full open or closed position they will drain the battery.
    Alternator may also have bad diodes.
    Do a current draw measurement on it. Then unplug the alternator charge wire and recheck, if no change remove the retractor fuses and recheck
  1. Who wants to help install a Weber?
    By 91lowrider in forum 2geez Tech & Performance
    Last Post: 05-20-2012, 04:15 PM
  2. DIY: Complete 32/36 Weber DGEV Install *Lots of Pics*
    By charliefowle03 in forum Carburetor Tech
    Last Post: 04-14-2012, 09:02 PM
  3. Weber install success story - 32/36 + Questions
    By MrSamson in forum 3geez Accords
    Last Post: 07-24-2011, 02:51 PM
  4. Weber install with pics
    By 86dxhatch in forum Carburetor Tech
    Last Post: 03-09-2011, 04:24 PM
  5. Weber install ?'s
    By cspeed in forum Carburetor Tech
    Last Post: 04-07-2003, 07:10 PM
