Results 1 to 8 of 8
Thread: Ignition switch replacement simple question.
    Aug 2015
    1986 Honda Accord LX
    CA
    I have a simple question I checked the ignition switch with a multimeter by disconnecting the cable and then reconnecting it. My questions is when I now open the driver side door there is a beeping sound. I don't remember that happening before. Is my car suppose to do this without the key in the ignition? Is this beeping sound to let me know that the door isn't close all the way or is something not right? I could have sworn the only beeping I heard was for the seatbelt warning.
    86 Honda accord lx, auto trans, ac with 2bbl keihin carb
    Nov 2017
    Re: Ignition switch replacement simple question.
    Quote Originally Posted by lx 1986 View Post
    It beeps a certain way when you leave the key in the ignition, and another way when you leave the lights on. I think you shorted something out.
    Aug 2015
    CA
    gcovarrubias412 thanks for the response. I'll check to see if something happened
    Nov 2017
    No prob
    Check the two door switches near the door striker plate one may be damaged. You may have to unhook the box until you get it figured out its under the radio.
    Aug 2015
    CA
    Thanks for the help gcovarrubias412 and Oldblueaccord I fixed the problem no more beeping when I open the door.
    Nov 2017
    Nice! What seemed to be the problem?
    Aug 2015
    CA
    Oldblueaccord might have been right about the door switch setting that off. I started pushing on it and the beeping stopped.
  1. Ignition Switch ??
    By sloweddi in forum EFI Tech
    Last Post: 07-16-2013, 12:14 PM
  2. Simple and cheap solution to bad ignition switch
    By Legend_master in forum 3geez Accords
    Last Post: 12-05-2012, 07:47 AM
