So I did some maintenance on the cooling system and replaced that little 2 inch hose underneath the intake manifold..... that operation was successful, now on to the stressful, LOL!
I've got no power out of 1 & 4. Checked the compression and got about 150 -145 on all 4 cylinders (out of a 360k motor, not great, but not bad.) Also, that dam compression tester was a loaner tool from O'riely's all messed up. I could feel a leak in the hose while cranking, so who knows.... at least I know it's 145 or better.
I've got spark on all 4 cylinders.
I've got 12 volts to each injector on the (+) side, and I have 2 ohms on the injector itself
I plan on doing the injector swap around to see if the dead'ness follows the injector over to #2 or #3
My question to everybody here is, is their something that might be considered a "sensitive zone" around the coolant line work I did? Has anyone ever encounters a similar situation?
Everything was great before I did the work on that hose. I can't imagine that a simple trip up and down the car ramps did anything that wild! Hell, was still getting 31 mpg over the past week.
Any help to my little blue 3'rd gen Accord would be GREATLY appreciated![]()
