Here's an update. Got that shit back from the machine shop. Looks yummy. That head was crusty as fuck, and they had to use the parts from the cracked head I brought in. So in this case, two heads were better than one! (ba dum bump!)
Got a cam regrind (stock profile, it was worn pretty badly), valve grind, all new seals, adjusted, cleaned, milled, tested, good to go. $450.
The cracked casting I took in:
The crack was so small, my camera couldn't even pick it up... But I guess pressure and heat let a lot of liquid through that tiny crack!
The FACTORY 3-angle valve grind. You can see it here in this pic. I'm sure my refurb'd head with the regrind doesn't have that...
All the leftover parts.
And now the new deliciousness:
