Results 1 to 19 of 19
Thread: need help with tuning..........
    LX User fijisac's Avatar
    Feb 2009
    1989 honda accord LX
    sacramento, california. 91sickness
    ok so on da way home today from work, dis 95 civic ex was messing with me so i punched and so did he, and i lost so i just wanted to know what i can do 2 make my car faster. its a stock LX with 5 speed tranny, but i cant do a efi swap (ause i live in a apartment) and i dont have enough for a weber carb, so is there any think i can do, if so plz tell me
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: need help with tuning..........
    Fart can, ricer wing, and flipped air lid shoud take care of dat mon...
    lol
    CARDONE SUCKS.
    Feb 2009
    lol
    lol ur joking right? anyways i sm will to but some money into it but it will takes some time tho
    Joay's Avatar
    Sep 2008
    Misty Beige 1988 LXi Coupe
    Meh. It's carbed, so the only reasonably effective thing to do is get a new carb.
    Best free mod is to gut the interior.
    If you can't afford a Weber, look into a Holley 5200 type of carb. They can bolt on in place of the Webers. There's also work to be done on the stock carbs. Do a de-vacuum, get a 4-2-1 header from an EFI car, do the manual secondary conversion. Advance the timing a couple degrees. Get a cam from an EFI car as well. Scavenging at the junkyard, you can probably get all that stuff for around $100 if not less.
    i have a stock efi cam...hehe...
    Nos
    Feb 2009
    wut is the different from da carb caM AND EFI CAM, is da efi cam bigger or something and can i use da same timing belt? how do i do a de vacuum and how would i rewire to o2 sensor since da efi header had 2 and da carb header has 1 o2 sensor and what is a manual secondary conversion? sry for all the question but dis is my first time tuning a car like dis
    efi swap and cam,header/I/H/E...and your golden
    Feb 2009
    well i guess dat would be da best bet, its going 2 b hard to get all da parts together but it can be done, but i have just 1 question bout da ECU, can i use da ecu from a 2door lxi or does it have 2 be 4door lxi ecu since my car is a 4door?
    I have a EFI manifold sitting around that you can have if you want it.
    and a ecu if you need one....just pay shipping....its a 89lxi so idk if it well work...since it has the duals tb
    A wet shot of nitrous will be your best, cheapest, easiest way to make power and pwn some people. Your car will barely be faster with an EFI swap. And completely un-tunable if you run the stock computer. Don't waste your time unless you're doing a serious build.
    bottle your baby....
    I wish you could chip obd0 motors... *sigh*
    Feb 2009
    well i'm going to try 2 make a ghetto intake first then i will go on from there, i might get a flowmaster or a magnaflow with a 2.5 inch pipe from the cat all the way to da exhaust. then i will see wut else i can do, i might even do a swap
    gl with a swap.
    Jul 2008
    I wuld say 2 get da xaust dun wit 2 point 5 pipin' and put efi on dat car and get a niice fart can wit sum nooooooooos
    5.25 Memphis Mclass fronts
    6x9 Memphis PR Rears
    Street Edge amp
    15' Memphis PR sub with ported box.
    Next, head work, new exhaust(2 1/4 inch) and cam.
    get some super small tires....you will rev faster just wont have alot of top end
  1. engine tuning ?
    By H86accord in forum Performance
    Last Post: 02-02-2012, 08:33 AM
  2. Honda Tuning
    By 86ccord in forum Classic Honda Community Chat
    Last Post: 06-17-2009, 10:50 PM
  3. Steering tuning?
    By cyra in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-30-2008, 04:10 PM
  4. Tuning vs. Modding
    By BeatThisLXI in forum Performance
    Last Post: 12-05-2006, 01:26 PM
  5. Amp tuning.
    By Imran in forum Interior & Exterior Care
    Last Post: 10-07-2004, 10:33 AM
