Sorry, yes you would have to put the manual flywheel & clutch on as well...
In that first pic it looks like you have a huge rusty cock!
Whatever the case that pump is the worst I have ever seen, I can't imagine what the tank looks like let alone the lines(if the even let anything through).. can't say I recommend it.
i was gonna drop the gas tank this weekend and put the tank off my other car and the fuel pump as well into that car and the car has not had gas run through the gas lines in five years
and i was also gonna put the air compressor up to the lines with both ends and blow it out and see what comes out... if that would work
if your plannin on reusing the gas tank id suggest a product called kreeme , used this on my vintage dirtbikes and worked out fine
http://www.kreemproducts.net/c-6-combo-packs.aspx
your gonna need to change the fuel filter too, im sure its plugged tight. The lines probably have alot of junk in them as well
