Results 1 to 17 of 17
Thread: Weird Knock sound when Brakes applied.
    LX User SOHC's Avatar
    Jul 2009
    1987 Honda Accord EX-i
    CANADA
    I get a wierd Loud Knock when I start to press my brakes.... I think it might be the stabilizer bar sliding back and forth?
    Re: Weird Knock sound when Brakes applied.
    control arm bushing(s)
    Jul 2009
    CANADA
    Theres a Brand New Control arm in it. I put it in Last week.
    Y?
    something is loose obviously, check everything..those are not supposed to be torqued balls azz tight because they need to move up and down freely but sometimes they are left a little too loose so you have end to end movement.. not what you want.
    Jul 2009
    CANADA
    I take a pic of y I replaced it, I do believe I cranked it down quite tight, but I could be wrong. Its a nice day today no more bloody rain ( 2weeks) I think I'll go make sure,
    thanks Roodoo
    Feb 2004
    89 accord lxi
    down by the bay
    Also check to make sure you don't have a broken caliper bolt.
    Jul 2009
    CANADA
    when I touch the brakes I get a *ting* sound, like its coming from my coilover, But I can feel it in the Wheel and on the pedals. so I have no Idea what it could be I was under my car for like 4 hours today lloking for that sound checking every bolt!
    AZmike's Avatar
    Tucson, Arizona
    Did you check the radius rod nuts on the front cross member?
    Mike
    1ajs's Avatar
    slurpeepeg
    motor mounts
    axles
    struts
    plastic gravel gard it makes a fare bit of noise beleave it or not...
    ur shocks?
    hows ur bearings on the front?
    hows the disks doing
    also u check ur pads?
    If you feel it in the pedal then it sounds like the rotors are warped. Also any loose steering part will make this "rockin" noise much worse.
    Jul 2009
    CANADA
    I hear the *ting* sounds when ever i hit a bump or when I shift, It pretty much happens when the Front end drops during a shift or a small dip, enought to make the coils bend.
    Standard front end check:
    1: jack up one side of the car until one tire is off the ground. The other side tire must be on the ground. I use the jacking point under the doors.
    2: grab the tire in the air at the 3 and 9 o clock postion and shake/rock back and forth. slow at first. You might need someone to help look underneath. This checks tie-rods,steering rack etc. start kinda slow and work your way up a little harder. Your looking for loosness at the joints. Use common sense of course the steering wheel will move or the other tire may move if you shake the shit outta it.
    3: Grab the tire 12 and 6 o clock. Rock back and fourth.This checks the wheel bearing and ball joints(upper and lower) and upper links(bushings). There should be no play in the wheel bearings.
    4: this check might show ball joints/upper link a little better. Use a pry bar under the tire at the 6 o clock pos. pry up look for slop ,looseness while prying. The upper link ball joint and bushings near the body are what your looking at.
    This is your basic "front end check" any good mechanic should know. It works for all makes and models of cars.
    Try this.
    Jul 2009
    CANADA
    I've done that. everything is tight, I get a Ping sound out of my coilovers now.
    I notice you say coilovers. As in not stock. If you did some suspension work, make sure your mounting bolts are all tight. You didn't hack up the springs or anything, right? Ham-handed suspension butchery can cause all kinds of fun. Odd noises could very well be the least of your worries.
    I just read your other post. You might want to be looking for rust in your shock towers.
    Jul 2009
    CANADA
    Yeah there coilovers, no I didnt even try to modify them, its all stock. I bought the car like this off my mother! I can post a pic if you'd like.
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    check the brake calipers , if its got the floating pins (the part that has the rubber seal that you use to bolt the caliper to the spindle) this happened on my 87 lxi, when i swapped the from brakes to the 89's i took both pins out and put anti seize on them
    jsut take the caliper off and see if they got play in them
  1. Weird Twirling sound in engine
    By 3geeJustin in forum 3geez Accords
    Last Post: 12-18-2006, 06:31 AM
  2. Weird sound, still there...
    By Sabz5150 in forum 3geez Accords
    Last Post: 08-12-2004, 04:20 AM
  3. lessen my lowering springs? cracking sound when brakes applied? Need answers
    By neoblue89lxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-02-2004, 10:13 PM
  4. Weird whistling sound when in 5th gear.
    By Chrome_thangs in forum 3geez Accords
    Last Post: 02-23-2003, 03:43 PM
  5. weird clicking sound
    By socal3rdgen in forum 3geez Accords
    Last Post: 11-03-2002, 02:12 AM
