Well I went ahead and replaced my front sway bar bushing. This eneded up being a bitch of a job.
I used the 9.5158 Energy Suspension bushing 7/8. This is a greaseable bushing. The brackets are quite a bit bigger and I ended grinding the bracket and open the hole some to work. This along with longer bolts and yes allen heads I made it work. Regular head would hit the bracket and I could not get them started.
Page not found
Looking over the Energy cat. I think the non grease able bushing,9.5126 would be the better deal and or the ones for the the Civic with a 22 mm sway bar. The center to center of the holes is quite a bit smaller.
I did alotta searching here and it wasn't really clear how much work and cussingI did to make the greasable ones work. So just some warning.
