Well it's not as easy as it originally looked.
I think this photo tells the whole story:
The good news is you don't really need new fenders. But there's also a piece of trim that is missing under the corner markers. So you probably need the JDM /EDM header panel, corner pieces, and probably the grille.
The header panel bracket might work. But I'm not really sure.
So, if anybody has a JDM or EDM header panel, grille, and corner trim pieces that go above the bumpers or underneath the sidemarkers, you should hook me up!!
At least you can see on the chassis how it was designed for the JDM lights:
Those are the adjuster holes with the arrows. You need some fancy tool to adjust them once they're in.
And that little notch, I think for a city light maybe. Have to investigate further.
