Hello all!,
My name is Patrick. I just bought me an 88 accord LX (carb) for $500! Great deal except it keeps overheating. So far that's the only major thing I can find wrong with it. I drove it for a full day a few weeks after I got and and got it legal and it ran great and it was like around 95 degrees outside but later in the evening about 6:00 it was getting hot all of a sudden and it broke down on me so I let it sit and put water in it and got it back to the house. So, here is what I have replaced on it to try and fix the problem: thermostat and gasket, coolant temp sending unit, radiator, and 3 jugs of coolant and no results. I've checked the upper hose its fine, not the lower one yet, water pump is not making any noise, the end of the heater hose was bulged so I just snipped it and put it back on, the oil is still oil and it is not milky or has any coolant in it. When it overheats the fans do turn on so I now its not the fans, although the temp gauge on the dash seems to go back and forth from working to not working. I just recently completely drained the cooling system to put new coolant in it and when I did white smoke was coming out of the radiator! Don't know what that means. I also took out the thermostat to see if that would help but it didn't seem to, I checked the upper and lower hose for heat, the upper got hot but the lower did not. I was expecting it to get hot a good bit after the upper did but it did not. I also tried bleeding the system but I cannot get a steady stream of coolant to come out, it just spurts liquid then steam. I checked on youtube and all of those its coming out of the tailpipe and its due to a blown or leaking head gasket. Is that the same problem I am having? This was the first time it has spewed white smoke. Any help is greatly appreciated! I apologize in advance if I have left anything out. Tomorrow I am going to test the cooling system pressure to see if it is leaking. I saw that on youtube too. Thanks in advance everyone!
