Results 1 to 21 of 21
Thread: Clean your battery terminals!!!
    DX User Shilo's Avatar
    Jul 2010
    1989 Accord LX, 1976 Nova, 1980 Plymouth TC3, 1985 AMC Eagle
    Virginia
    Exclamation Clean your battery terminals!!!
    When I first got my Accord, the battery terminals where pretty corroded. Well, I forgot to clean them off. After I got my new exhaust on I decided to start it up to see what it sounded like. When I turned the key to the start position my car developed a mind of its own . The starter just clicked, the tach pegged and started moving on its own, the headlights kept opening and closing by themselves (out of sync to top it off). Instead of killing my zombie Honda before it could infect my other cars , I remembered I forgot to clean the battery terminals. I cleaned them up with a wire brush and some engine degreaser till they were nice and shinny. Problem solved . I wish I had it on camera though.
    LXi User Ayeobe's Avatar
    Aug 2008
    1989 Honda Accord EX-i AT
    Montreal, QC
    Re: Clean your battery terminals!!!
    Woww what the hell? That woulda been awesome on film. Thanks for the reminder, btw. I need to get the bigger batt in, and clean the terminals.
    Quote Originally Posted by Ayeobe View Post
    the low voltage causes problems with all of the electronics.
    the day i buy a car i install new grounds and new battery cables to prevent any such things from happening
    Aug 2008
    Montreal, QC
    Im rollin with the batt that came in the car, from a civic. I want to put a bigger one in, like i think it should have. And im deffenetly gona clean the terminals...
    it depends on how much extra load, as in the stereo etc you've added, these cars originally came with a very small battery. the battery does nothing but smooth out the voltage and start the car, the car actually runs off of the alternator.
    Aug 2008
    Montreal, QC
    I could use some extra voltage smoothing. When i put the signal lights on, i notice the dash lights dim as the green lights flash on. (thats at night with the radio off, fan at 2, and all lights on)
    I could use some extra voltage smoothing. When i put the signal lights on, i notice the dash lights dim as the green lights flash on. (that's at night with the radio off, fan at 2, and all lights on)
    that's a ground issue not a battery issue, the battery keeps the voltage from spiking from the alternator, with no load it can generate pretty high voltage. that's why you don't disconnect the battery with the engine running.
    Aug 2008
    Montreal, QC
    Theres white shit on my ground terminal. Guess ill clean it, huh? Ill do that tomorow, then.
    ground, postive cable, or alternator issue for sure
    Jun 2010
    should set up that situation again and video it, id love to see the headlights popping up and down out of sync, that'd be hilarious
    i should setup some switches to make them do that...
    and its funny this thread comes up, went to tstart it other morning and it clicked once and no power at all, ended up being the terminals caked in shit, thank god it was just that cause ive been through 1 altenator and 2 volt regs with this thing.
    LXi User SZfiftyfour's Avatar
    '82 Accord DX Sdn
    Ocala, FL.
    Back when I had a 3G, I had that happen while I was driving. I was messing around with it one day and forgot to tighten the negative terminal all the way before I drove off. Once it started working its way loose everything was cutting on/off in rapid succession. Add radio, fuel pump, and dash lights to the above symptoms while moving about 40mph. Crazy car.
    Btw you can do that to the lights by clicking the headlight button really fast. Dont know what the ramifications of this are though. Wouldn't recommend it.
    Jul 2010
    Virginia
    I found this video on youtube a few days ago http://www.youtube.com/watch?v=Jp5Qi...os=Oh9maL-KMu8. I just tried it with my parts LX-i and it wouldn't do it , but that's what my other Accord did when I tried to turn the key. Would be pretty cool to be able to do that on command, could really freak people out at night .
    Jun 2010
    that's fucking great!
    doesnt seem like it would be too hard to wire up, just some switches and wiring
    then you can wink at people ~.^ -.- ^.~ ^.^
    Aug 2008
    Montreal, QC
    Haha nice. Yeah, my 87 did it, when i pressed the button real fast but my 89 dosnt. Odd eh?
    Jul 2010
    Virginia
    Must be a sensor or something to keep the motors synced that the older years didn't have?
    LX User gtmst3's Avatar
    Jul 2008
    1986 honda accord LX
    Waterbury
    Quote Originally Posted by Shilo View Post
    idk cuz my 89 does that one actually lifts up faster than the other and i can make them wink if i want
    Jul 2010
    Virginia
    Quote Originally Posted by gtmst3 View Post
    Maybe mine is just too good, I'll have to try it on my other 89 later. I want to wink at people dammit .
    they all have the same motors and same control module, one motor is probably in better condition then the other is all. the linkage might need some white lithium grease at the pivots also
    Aug 2008
    Montreal, QC
    Update on the terminal thing. I went to losten the negative terminal, and just like the civic, it just popped off with the forse i was using to keep it on the nut. I didnt even get to losten yet. The stock terminals kinda suck! I put a new terminal on, and the dimming is fixed. Its also good and tight now. Thank god i didnt drive down to the US withought the "clean" i did! might have lost the neg. and had some prety big issues.
    DX User thornbird's Avatar
    Aug 2007
    1987 Accord LX Carb
    Des Moines
    Haha, for sh1ts and giggles you could easily wire one light up to a switch in the cabin and mess with people on the road.
  1. Battery light still on after replacing battery...
    Last Post: 09-23-2007, 08:42 AM
  2. The top of my exhaust pipe is clean, clean
    Last Post: 09-10-2007, 11:41 AM
  3. Replies: 2
    Last Post: 10-03-2005, 07:28 PM
  4. clean up leaky battery?
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 08-23-2005, 05:50 PM
  5. Battery Terminals?
    By StUpiD8000 in forum Interior & Exterior Care
    Last Post: 11-12-2003, 08:47 AM
