Page 23 of 49 FirstFirst ... 1319202122232425262733 ... LastLast
Results 551 to 575 of 1219
Thread: The Journey 89 turbo'ed-----89T
  1. #551
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Re: getting started again. 89T
    Damn dude that's some huge progress, this thing is going to be a BEAST!
    Can't wait for more! Also let us know how the brazing goes.. I am in the same situation for the tig.
    Andrew.
  2. #552
    I CAN TIG!
    not very good tho lol.
    that intake manifold, what sensors did u get rid of when u put it on?
  3. #553
    89T's Avatar
    Apr 2004
    update.
    Uploaded with ImageShack.us
  4. #554
    is ur front bumper gonna fit man??
  5. #555
    very nice! I didnt even think about putting the battery there either
  6. #556
    put the batt in the trunk. putting the batt there seems soo unsafe imo.
  7. #557
    89T's Avatar
    Apr 2004
    I CAN not very good TIG!
    lol. fixer-ed.
    all, but learning how to realign the flux capacitor while going back to a Honda ecu..
    lol.....nothing you cant handle.
    seen my spelling right? LOL!
    Hell if my gramer and spelling are good I have nothing to fear. LOL...
    their are noticeable differences, and I'll tune you in later.
    Bro.. I did not think of that .
    actually the intercooler was going to bein the area where the bumper was but a friend of mine rearended someone recently and changed my mind.
    very nice! I didn't even think about putting the battery there either
    You will massage the metal...LOL. did you notice the cut off switch?
    explain?
  8. #558
    explain?
    ur explanation is bolded.
    and did u really not thing about the IC pipes not fitting under the bumper???
  9. #559
    89T's Avatar
    Apr 2004
    Sorry i was buzzed last night.
    I knew they would fit, but what i really wanted to do was slide the intercooler under there too.
    The bumper cover fit's over the pipes nice.You cant even tell that they are there with the bumper cover on.
    why would you not put the battery there?
    I removed everything that was attached to the stock manifold including the black box. I then ran new wires to the map sensor from the firewall area to the gm 3bar map sensor that is mounted under the manifold. you still need the iat,map,throttle position and the idle air control valve.. I think i am missing something though.
  10. #560
    89T's Avatar
    Apr 2004
    As you can see in the pic there are 2 spots i brazed together.
    The spot in the middle of the car came out pretty good except I didn't Polish it enough. On the drivers side I had to braze it on the bend.
    Let me explain. That particular bend was a U bend, and you know U bends are not perfectly round .
    the brazing actually works very well, not the prettiest thing till you sand it smooth and Polish it. I purposely tried to break it and it held up fine.
    I picked the stuff up at harbor freight and spent about $20 for the rods and polishing kit. Was it worth it. I think so.
  11. #561
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Because in a wreck you either have a 60 Lb projectile or a damaged battery. Youd have to hit somethin pretty hard to hit it where you have it mounted, and i assume how you have it mounted is pretty solid. I think if you smacked it hard enough to damage the battery the battery would be your last worry anyway.
    On those pipes, just be sure you won't have leaks.
    '89 SE-i Coupe
    Awaiting Garage
  12. #562
    89T's Avatar
    Apr 2004
    Yes sir, The battery is still in the process of being mounted and will be solid.
    When all is said and done i am going to pressure check all the piping and intercooler as one.
  13. #563
    lol @ u being buzzed.
    mani sounds like good stuff, i wanna do that.
    as far as the batt, i dono i guess its a personal thing, i really dont know why but i dont think its safe there. but do wut u gotta do! ur car is gonna be sick!
  14. #564
    89T's Avatar
    Apr 2004
    Right on
    Remember that i dont drive it all that much, so it should be fine.
  15. #565
    true.. well more power too ya!!! i wanna see u hit like 3453058320million hp wit ur set up.
  16. #566
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    all 3 inch piping?
  17. #567
    89T's Avatar
    Apr 2004
    Yes sir, I went with all 3". I know it's an overkill.
  18. #568
    89T's Avatar
    Apr 2004
    Tonight I am working towards finishing the w/a intercooler brackets, and the battery tray.
  19. #569
    no pics no care.
  20. #570
    89T's Avatar
    Apr 2004
    I got's you some pic's son.
    No J/K..lol, I need to make 1 more bracket for the battery. then i'll post pic's
  21. #571
    nice progress. makes my setup look hacked haha. Dont you love all the custom work needed to make stuff fit?
  22. #572
    89T's Avatar
    Apr 2004
    Thanks, and It would'nt be so bad if all the little stuff didn't take so long to make..
    speaking of little stuff. I got the battery in.
  23. #573
    89T's Avatar
    Apr 2004
  24. #574
    2drSE-i's Avatar
    Oklahoma City
    How far off the ground is that? Not that it matters, just curious.
    '89 SE-i Coupe
    Awaiting Garage
  25. #575
    89T's Avatar
    Apr 2004
    The bottom of the tray is 7.25" . The front cross member is lower than the battery tray.
  1. Turbo 3G role call... Paging turbo'ed guys
    By AccordEpicenter in forum Forced Induction
    Last Post: 06-07-2011, 11:26 AM
  2. My MPG Journey
    By soonerck in forum EFI Tech
    Last Post: 03-18-2011, 08:58 AM
  3. for the turbo guys/wana go turbo/dream of going turbo
    By ZackieDarko in forum Performance
    Last Post: 01-14-2007, 11:22 PM
  4. Replies: 8
    Last Post: 02-11-2004, 05:30 PM
