Going to eventually convert to a manual abd found an accord at the junkyard with a trans i will attempt to rebuild. Question, how do you disengage the shift rod from the transmission? I have disengaged it from the stick
There is a spring pin on the transmission that you need to punch out.
Im assuming im dropping the trans with the rod still engaged then? Or is there a way to do it in chassis? Cant find nuffin in the service manual about this part. Wheres the pin btw?
Remove the bolt
Really afraid that was the answer . Bolt is rounded off
Got it. Pleasantly surprised by how small this thing is. I can pick this up with ease
Oh yeah, there's pin on these cars (The Civic does).
It's a bolt indeed
Too bad i went through the trouble of removing it only to find the internal speed sensor housing in the transmission is cracked/broken. Not sure if sonething like that can be fixed or not. Trans is still sitting in the trunk of the car in the junkyard
Yep. I know.. but where it fits inside of the transmission is cracked. The sensor itself is fine. I dont know if it would be any difference. Wish i coulda took a picture
Pffft, who needs a speedometer
Originally posted by ShiRen:
I'm pretty sure that could be fixed at a machine shop, but you might not like the price.
