Ok this is where it mounts, sits right up high on the firewall, working on a piece that mounts to the firewall, it's basically a long block, one end goes to the canister carb inlet, the other goes to the valve that is open when the engine is running. the two carb bowls connect in the middle, and the bottom fitting goes to a check valve,this will allow the carbs to vent in an emergency if the valve fails. it's a little more complex then that,but thats the simple version,. basically when the engine is running, the vaccume valve opens letting the carbs vent to atmosphere,when the valve closes, the vapors are absorbed by the canister to be reburned later.![]()
