Originally Posted by
2drSE-i
Alright, so after adding 3 quarts of oil for the second time, I'm SICK OF IT.
Here is what the car is going through. It currently has no PCV system hooked up, and its dripped a bit of oil for a while. I changed its oil a little over 1000 miles ago, and my oil light came on. Immediately pull over, hear some tapping from the valve cover, fill it back up with oil (took 3 quarts....i was pissed, but glad i keep a bunch in the trunk) and go on my way. A WEEK later, i check my oil, and it shows nearly empty AGAIN. Again, it took nearly 3 quarts (2 1/2). This was today. I jacked it up after filling it with oil, notice no (significant) drips, as i said, it leaks a bit anywho, no more than a quart between oil changes. I start the car, and within 10 seconds i have a significant leak. Not a stream, but a solid drip drip drip drip.
I checked around a bit, and this is what i have.
-Oil return hose from breather box to oil pan is fine. No leaks.
-No leaks from oil filter
-No leaks from oil filter base
-No leaks from Oil drain plug.
-No observable leaks from Oil pan. Initially it looks like this was the problem, but after looking at it, oil is running over the oil pan. There is oil on top of the "ridge" of the oil pan, if you understand what i'm talking about.
I spoke with Tim (lostforawhile) about it, and he seems to think that the O-ring from the breather box to the block is bad. Any other ideas? Thanks for the input!!
Edited to add:
Oil is flowing from over the oil pan, down the pan, and over the "hump" in the pan, and runs down near the drain plug, to the ground. It is also flowing down somewhere else (that i can't readily see) onto the exhaust. LOTS of smoke.
