Results 1 to 15 of 15
Thread: NEED HELP ASAP!!! 89 honda accord lxi lower ball joints...
    DX User 89accordlxigentyers's Avatar
    Feb 2011
    89 Honda Accord Lx-i
    Urbana, Ohio
    Question NEED HELP ASAP!!! 89 honda accord lxi lower ball joints...
    Ok im replacing my lower ball joints on my 89 accord lxi with 302xxx miles on her...
    My ? is there is a steering knuckle ring on the back of the hub thats in the way of the lower ball joint being pressed out. Do I need to remove that s.k.r to remove the ball joint and replace the s.k.r? Or can i just reuse the ring???
    Needing an answer asap cause it will take at least a week for the part to be delivered...
    Thank you and have a great day 3gezzers...
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: NEED HELP ASAP!!! 89 honda accord lxi lower ball joints...
    yah that dust ring you reuse, that's for the bearing. it needs to be taken out to have enough room to get the ball joint out
    3Geez resident body man
    Owner of Wreck-less auto body
    Not sure about the ring part but usually the whole arm is taking out and a pressed is used. A few here say you can beat them back in with a hammer and socket but the angles seem impossible to me.
    Feb 2011
    Urbana, Ohio
    so gp i can re use the dust rings just by using a pry bar to ease them out and tap them back in with a rubber mallet? im using the moog lower ball joints and just bought 2 dorman upper control arms with bushings i no there really low end control arms but im in a pinch for cash till i get my taxes... know anything about dorman products?
    Feb 2011
    Urbana, Ohio
    Oldblue i have access to a shop with a press so i dont have a problem with that atleast i dont think ill have a problem with that lol...
    1989 Lx-i Hatchback
    Jackson, NJ
    Quote Originally Posted by 89accordlxigentyers View Post
    yah on the dust ring, dorman stuff i don't buy , id rather spend the extra on the moog.
    Feb 2011
    Urbana, Ohio
    ok well im waiting till i get my taxes to get th moog control arms with the uppers in them cause there like 150 at my advance auto...
    Millington, TN
    GOTO: www.rockauto.com
    I always just used a 3lb sledge and a heavy punch to replace the ball joints.
    Phil
    1989 Lx-i Hatchback
    Jackson, NJ
    yah that will work fine , if its really stuck in there then you will need a press
    Feb 2011
    Urbana, Ohio
    ok thanks alot guys for all the info but my lps is out of ball joint kits so would i just be able to use a c clamp w/ a 32 mil socket to press them in and out???
    Millington, TN
    If they are rusted in there, torch wrench and PB blaster penetrating oil, 3lb sledge and a heavy punch will get the job done.
    Phil
    Nov 2000
    I know what you mean! I got a pair of Moogs that were closeout specials at Rock Auto for $40 each. I bought cheaper ones in 1988, but they lasted less than two years before the balls joints had play in them and for that whole two years they made creaking and squeaking noises. The Dorman ones have to be better than those eBay ones I bought. I bought them when I was unemployed.
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Working on memory from like 4 years ago i believe there is a ring behind that shield that has to come out. Don't remember it being a pain tho.
    Feb 2011
    Urbana, Ohio
    ok guys im going to give it a shot with out the ball joint kit tonight and ill let yall know how it goes... im hopping it dont take any longer than 6 hrs lol... thanx for the help...
    Feb 2011
    Urbana, Ohio
    ok guys i cant believe how well my car handles now its like a new ride its so amazing.... new upper a arms with ball joints lower ball joint cv shafts and tire rod ends... putting on some new tires this weekend too... thanks for all the help... btw i just took the lowers to napa and they only charged me 50 to press them so its all good now...
  1. lower ball joints 89 lxi
    By wallacefan in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-05-2006, 08:41 PM
  2. lower ball joints
    By AccordNut in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-31-2005, 11:40 PM
  3. lower ball joints !
    By ACCORD EX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-01-2004, 06:27 PM
  4. Lower Ball Joints
    By swiftly_driven in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-13-2003, 09:53 PM
  5. Lower Ball Joints
    By HondaManDan in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-25-2003, 10:58 AM
