Page 25 of 44 FirstFirst ... 1521222324252627282935 ... LastLast
Results 601 to 625 of 1084
Thread: Tdurr's round two!
  1. #601
    Re: Tdurr's round two!
    Haven't not been on the forum for awhile . I want a vid of u smashing patna. Lol btw that 2 step sounds nasty
    lol i gotta fix my window or figure out a new mounting spot for my camera so i can get some gear banging videos man. Its still kinda slow, but thats why i have the turbo waiting. and its looking pretty good that the end of next month it might be going down!
  3. #603
    Ouch!
  4. #604
    Yeaa. Thankfully it was just the headers so its no biggie. Those will be coming off soon enough.
  5. #605
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    well since you have never responded i have something for you.
    found this in my door panel.
    kept hearing a clicking and my batt kept dying randomly. so i did this after super gluing the cap back on.
    there is also all of this crap behind all panels. I swear this car was flooded man. anyone have a carfax??
    also got you a lil video too.
    https://www.youtube.com/watch?v=BLe-...ature=youtu.be
    I have had the parasitic draw in my hatch for a while now too. I was thinking that it was the alarm I had put in
    That is the fix for the parasitic battery drain in coupes. It's about the most elegant solution I've found.
    I have to give this a shot myself. What does the plug go to?
  6. #606
    Quote Originally Posted by bullard123 View Post
    Search NEWB!!! LOL
    https://www.3geez.com/forum/technical...w-battery.html
    They keep the belts from locking when you have the door open.
  7. #607
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Search NEWB!!! LOL
    Ha ha...... Thanks Snooz. I disconnected both plugs today and now I get the flashing seatbelt symbol on the dash with the chiming noise. I even pulled the fuse from under the hood and I still get the chiming noise when I start the car up
  8. #608
    Ive never got tge the chime. Do these cars have a headlight buzzer?
  9. #609
    LX User JohnBoy's Avatar
    Nov 2008
    87/honda lxi accord, 04 xterra, 87 f-150, 93 f-350, 75 camaro, 01 gsx-r
    spokane, WA
    it like the headlight buzzer or the door buzzers its under the dash.
  10. #610
    welp, i got a powdercoating gun from Mushroom_toy the other day and have been itching to test it out. Got the pins from the flushmount hood pins that ive had chilling stripped then powdercoated.
    here are some pics (i forgot to get a before and after)
    ^^^^ curing the powder.
    Finished product.
    then i went and ordered a bunch of powder because i got paid today... lol so ill start powder coating stuff in the bay soon... cuz i can now.. muhahahahaha
  11. #611
    Finished product.
    That is a pretty cool toy to have!
  12. #612
    yuppp. im so excited man. i hope to try and get a side business going in the long run if i can get a good set up.
  13. #613
    Beautiful results with the hood pins. How do you expect the finish to hold up?
  14. #614
    I see them holding up pretty well. I smacked them around against each other for a bit and no scratches so I figured it would do fine since it is going to not hit anything metal.
  15. #615
    Nov 2008
    spokane, WA
    powder coating is great the only better thing is cerakota but its twice as much.
  16. #616
    Yea, im thinking of cerakotaing the turbo manifold. But idk if it will happen right away
  17. #617
    Nov 2008
    spokane, WA
    I do it for guns and was thinking of doing the cerakote slip on the pistons for my engines.
  18. #618
    legit. me and my roomate have been talking about getting our guns done.
    also, status update.
    was heading home from picking up dinner and went to pull off from a stoplight, and just heard some banging. Then found this.
    so had to get it towed home. Then i got it pulled out and found this.
    went to napa to get a warranty exchange, and the fuckers closed a hour early today. why? nobody fucking knows, but now i have to get a ride in the am hopefully before work so i can get a non crappy paycheck -_-
  19. #619
    Well, today I went to honda abd got this:
    & was able to do this
    Went to go for a test drive then it almost happened again. My motor was sagging hard, did some searching and found this:
    Put the rear tq mount back on, and its driveable again. I think I might have to fab up a solid rear mount to fix this.
  20. #620
    cygnus x-1's Avatar
    Chicago area
    Yeah, something is way wrong here. Did the rear engine/trans bracket lose a bolt and slip or something? Or is it bent? Because that bracket should be parallel with the top of the rear cross member.
    C|
  21. #621
    the bracket is parallel with the rear crossmemeber. I was lacking the tq mount, and the lower trans brace mount, I really thing my front mount is just off by a hare so its throwing everything else off. Idk. we shall see.
  22. #622
    cygnus x-1's Avatar
    Chicago area
    Put the rear tq mount back on, and its driveable again. I think I might have to fab up a solid rear mount to fix this.[/QUOTE]
    When you put the upper torque mount back on, does the rear mount go back to looking like the first picture? Comparing the the two pictures, the position of the engine/trans bracket is very different in the second one. Either that bracket is bent (or missing a bolt) or the engine is sagging towards the front a LOT.
    C|
  23. #623
    the engine was(is now) sagging towards the pass side. i have no idea what exactly has changed, but i might need to get my front engine mount remade and my rear one made into a solid piece. Just broke a 2nd axle pulling out of the driveway....
  24. #624
    cygnus x-1's Avatar
    Chicago area
    I'm 90% certain you don't need a solid rear mount. However, if you decide you want one anyway I could make you an aluminum block to fit in place of the poly mount for pretty cheap. Say $40 shipped.
    C|
  25. #625
    There's too much POWER!!!!! LOL
  1. Tdurr's Turbo Thread!
    By Tdurr in forum Forced Induction
    Last Post: 04-02-2012, 08:56 AM
  2. Tdurr's Offical Thread
    Last Post: 04-16-2011, 12:59 AM
  3. Tdurr On New Wheels
    Last Post: 10-31-2010, 01:05 PM
  4. Tdurr's pedoccord in action
    By e30pwr in forum Classic Honda Pics & Videos
    Last Post: 03-29-2010, 03:39 PM
  5. Tdurr Comes to Savannah!
    Last Post: 04-11-2009, 07:50 AM
